morel lifters #2724388
12/16/19 08:24 AM
12/16/19 08:24 AM
Home of the Bluegrass
MoparJunkie Offline OP
Hey guys, I'm building m,y 500" 440 RB stroker and I'm using the TF 240 heads with the TF .600" roller cam. Upon assembly I've primed the engine to make sure all is well...... The lifter on cyl 1 intake wants to spew oil out from around it like a geyser when it is at the top of the lift. It's the only lifter doing it? I'm using the race hydraulic rollers that hughes sells PN 6074..... I went with these because i heard they were the best.... Any thoughts???? I'm gonna have to remove it to see if there is any difference between it and every other lifter installed. Just wondering if anyone has seen this or is familiar with any pitfalls like this?
TIA up
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: morel lifters [Re: MoparJunkie] #2724391
12/16/19 08:45 AM
12/16/19 08:45 AM
North America
K
kwikblownhemi Offline
K
North America
I used a set in a 493 build a few years ago. The oil groove that feeds the internals of the lifter extends 0.118" above the top of the oil clearance band on the body. The cam we used was .580" lift and the groove was just at the bottom of the chamfer of the lifter bore at max lift. All 16 leaked. We ended up bushing the lifter bores.
Re: morel lifters [Re: MoparJunkie] #2724394
12/16/19 09:08 AM
12/16/19 09:08 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Your uncovering the oil galley at full lift just as you said. I had same issue with my SB. I had to find a lifter with short skirts/windows to fix the issue. I tried comp, crane and morel. The morels fixed the issue and turned out to be a very good solid roller lifter running on .714" lift on the street. I used them for 10 yrs rebuilding them every 5yrs. The car doesn't get a lot of miles on it thou, but the miles it did get were hard miles. I thing I paid $250 for the set at the time thru Erson cams.
Re: morel lifters [Re: MoparJunkie] #2724398
12/16/19 09:44 AM
12/16/19 09:44 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Sorry to hear of your troubles with the hyd roller!I did'nt go hyd for this reason and went with a comp 829 solid body.Do you use a factory block?Could you tell me the push rod length you use?
Re: morel lifters [Re: kwikblownhemi] #2724399
12/16/19 09:46 AM
12/16/19 09:46 AM
They advertise that you don't need bushed lifters...... flame
Re: morel lifters [Re: MoparJunkie] #2724412
12/16/19 10:31 AM
12/16/19 10:31 AM
North America
K
K
North America
I've used their solid rollers in builds several times since, but no hydraulic rollers.
Re: morel lifters [Re: Clanton] #2724432
12/16/19 11:40 AM
12/16/19 11:40 AM
Factory block and pushrods were 8.9ish on the length? I have the measurement somewhere from when I ordered them....
Re: morel lifters [Re: MoparJunkie] #2724439
12/16/19 12:03 PM
12/16/19 12:03 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Thank you for the reply.
Re: morel lifters [Re: MoparJunkie] #2724454
12/16/19 12:30 PM
12/16/19 12:30 PM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
Does the oil feed hole really extend above the band like in the pic?
Re: morel lifters [Re: fast68plymouth] #2724457
12/16/19 12:46 PM
12/16/19 12:46 PM
Dwayne, I'll have to look tonight???
Re: morel lifters [Re: MoparJunkie] #2724458
12/16/19 12:48 PM
12/16/19 12:48 PM
Dwayne, I will say Hughes tells me that's not an issue due to lifter only being there for a short time period..... I'm not buying that, what say you????
Re: morel lifters [Re: MoparJunkie] #2724469
12/16/19 01:16 PM
12/16/19 01:16 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Do you have the passanger side oil passage restricted to the lifters?
Re: morel lifters [Re: MoparJunkie] #2724472
12/16/19 01:20 PM
12/16/19 01:20 PM
North America
K
K
North America
I can tell you that at high RPM you'll aerate the oil and the lifters will collapse.
Edit: IF they all leak. Ours were.
Re: morel lifters [Re: fast68plymouth] #2724473
12/16/19 01:22 PM
12/16/19 01:22 PM
North America
K
K
North America
Yes it does. I have a picture here somewhere of the actual lifters I used. The picture I posted is off Morel's site. This was discussed some time ago on Speedtalk and I think here too. I posted a picture on ST, not sure about here on Moparts.
Re: morel lifters [Re: Clanton] #2724478
12/16/19 01:33 PM
12/16/19 01:33 PM
No, I was told I didn't need to do any mods to run this setup.....
Re: morel lifters [Re: MoparJunkie] #2724480
12/16/19 01:50 PM
12/16/19 01:50 PM
So. Burlington, Vt.
So. Burlington, Vt.
Only one way to know for sure.
Are these “real” hyd lifters, or limited travel lifters that are basically cushioned solids that are set off of the bottom of the plunger travel?
If they’re a “real” hyd lifter that have a pretty normal amount of plunger travel, and you’re going to run them with typical hyd lifter preload, then I probably wouldn’t run them like that, especially if that oil feed hole is extending above the lifter bore.
If they’re limited travel lifters that you’re going to set up at something like .010-.020 off the bottom, then I don’t think the leakage will matter at all....... other than whatever affect it has on the oil pressure.
The easy test to see if it’s the block or the lifter, just swap in a pair from a different cylinder.
The leak either follows the lifter, or stays with the bore.
Re: morel lifters [Re: MoparJunkie] #2724482
12/16/19 01:55 PM
12/16/19 01:55 PM
North America
K
K
North America
I feel your pain. Those are expensive lifters, but like everything in the aftermarket, nothing is plug and play. I check things now I didn't even think about 45 years ago.
The block the guy used had a really deep chamfer on the lifter bores, several lifters squirted oil out onto the floor when the pump was spun.
Re: morel lifters [Re: fast68plymouth] #2724486
12/16/19 02:00 PM
12/16/19 02:00 PM
That's what i plan on doing to see where the issue is.... block or lifter.
Re: morel lifters [Re: MoparJunkie] #2724493
12/16/19 02:37 PM
12/16/19 02:37 PM
If your seeing one lifter gush oil with it at max lift you know they all will, correct shruggy work
I saw a similar problem on a set of solid roller lifter on a early street Hemi block years ago, the driver side lifter oil galley was machine lower in relation to the main bearing centers witch made the bottom of the lifters expose that oil galley at max lift when running, which made the oil pressure vary at idle puke
I ended up blocking that oil galley off as those lifters where the good early Engle lifters that had that side(oil galley side) of the lifter body longer than the center side of the lifters.
It sounds to me like you will need a different, longer body lifter or have the block bush and make sure the machine shop has the bushings extend above the lifter bores also to fix it. I don't think I would do that though before making sure I couldn't use another brand of lifters to cure that problem work scope twocents
Another solution could be to have that camshaft reground to lower the heel of the lobes, like a small base circle grind, which will lower the lifters in relation to the lifter bores which might cure your oiling issues work shruggy
Good luck either way, let us know your solution please thumbs
Re: morel lifters [Re: Cab_Burge] #2724499
12/16/19 02:50 PM
12/16/19 02:50 PM
Cab...... I only saw this one causing the issue. I checked all the others while priming and rotating the crank multiple times.
