What ‘72-‘80 D-Series Trim Packages? Custom, Advent?
#2723903
12/14/19 01:51 AM
12/14/19 01:51 AM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Is there a definition or list of options, trim package, etc, that would be built into/included in a “Custom” vs “Adventurer” model, etc?
Was the “Custom” the Base model? What models were available in 1974?
I own a ‘74 W200 Custom 200 pickup and was curious.
Re: What ‘72-‘80 D-Series Trim Packages? Custom, Advent?
[Re: Alaskan_TA]
#2723931
12/14/19 09:35 AM
12/14/19 09:35 AM
RWG75
RWG75
I can't tell you piece by piece, year by year, but this is the generalized version: Custom was the low end and pretty much means no side trim and a plain chrome strip across the dash. Adventurer was mid level trim and included the upper side spear, tail light surround and a wood grain strip across the dash. SE was top level trim and included Adventurer items plus lower side moulding, woodgrain dash face and longer door panels with carpeting along the bottom. As near as I can tell, 80 / earlier Prospector package was a custom with a side spear but none of the other Adventurer items. I think the woodgrain door panel insert was part of the Adventurer package in some years, part of the SE package in other years. Pretty sure the aluminum tail gate insert was SE only. I also think Custom was low back buckets or bench while SE was the optional (in lower trim levels) high backs as standard. Try browsing around these two sites - they both have a big selection of original dealership brochures: http://www.lov2xlr8.no/dodge.htmlhttp://oldcarbrochures.com/The 76 pickup brochure on the first site seems to have the most info. http://www.lov2xlr8.no/brochures/dodge/76pick/bilder/9.jpg
[Re: D_C]
#2723973
12/14/19 12:19 PM
12/14/19 12:19 PM
Posts: 738 Middle TN.
4x4 Roundup
Middle TN.
Thanks The top trim level in '74 was called an Adventurer Sport.
WANTED-- DEAD or ALIVE: '70 Duster--- VS29H0B274908-----UPDATE---ENGINE BLOCK FOUND---Still looking for the B-5 car. '79 Power Wagon W14JE9S137761 or 763
[Re: D_C]
#2724060
12/14/19 08:31 PM
12/14/19 08:31 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Some years such as 1975 they made an Adventurer SE which I think was top dog. SE and Adventurer also had 2-tone paint. I thought the Prospector was 81-up Then there was also the Camper Special option not to mention Macho, Warlock, Little Red and Big Horn models.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2724089
12/14/19 10:51 PM
12/14/19 10:51 PM
Posts: 1,093 It's beer:30 somewhere
adventurer
Not totally up on 74 but I'm sure it was about the same as 77-78. Like stated before Adventurer Sport was the top of the line in 74. Not sure on 75 but by 76 top of the line was Adventurer SE. Custom was the base model and Adventurer was the middle trim level. 77-78 Adventurer SE was special seat material, door panels, wood grain dash, emblems and several other things that really don't matter like dual horns, power steering, oil pressure gauge, AM FM radio etc..... Pretty much all models could have been ordered with the exterior trim, monotone paint and two tone in 3 different styles. So a customer could have been speced out with all the trim and two tone paint on a Custom but they usually were not. Hope that helps you
77 Dodge Adventurer SE 440 2wd SWB 78 Dodge Adventurer SE 440 2wd Utiline 90 Dodge D150 SWB 2wd 318fi 4speed 60 Desoto Adventurer 2dr 67 Dodge Dart Gt Conv. 273 4bbl 04 PT Cruiser GT Turbo 14 Ram R/T "Life's to short to drink cheap beer."
[Re: adventurer]
#2724103
12/15/19 03:05 AM
12/15/19 03:05 AM
D_C
Good to know.
My truck started out as a Pacific Telephone Utility Truck. It came with a LA 360 (largest engine you could get with the manual transmission). A friend has (or had) a W200 with a 440 and manual transmission, but it was not Factory.
A subsequent owner swapped on a Sweptline Bed. That bed was thrashed, so I found one in better shape off a ‘75 Pickup at a PIck-A-Part. This truck is a lowly Custom, though my replacement bed was off a more delux model.
DC
[Re: moparmarks]
#2724124
12/15/19 10:14 AM
12/15/19 10:14 AM
RWG75
RWG75
Some years such as 1975 they made an Adventurer SE which I think was top dog. SE and Adventurer also had 2-tone paint. I thought the Prospector was 81-up Then there was also the Camper Special option not to mention Macho, Warlock, Little Red and Big Horn models. Top Hand, Palomino, Pick-M-Up and a few other appearance packages as well. Camper Special was more of a hardware package and marketed toward people that wanted to slide a camper in to the bed. I think pretty much a 200 w/ dual tanks, heavier springs and I dunno what else. During the 80s the Adventurer and SE packages were phased out and replaced with (3) different levels of Prospector packages. I think the term is "badge engineering". I've seen the dealer brochures from the mid 80s that break down what's in each level. The pre 80 Prospector package seems to be an undocumented mystery. My one previous owner RC has the Prospector decal and the upper spear but a Custom emblem on the dash and no trim level option code on the under hood label.
[Re: ]
#2724231
12/15/19 05:19 PM
12/15/19 05:19 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
The top trim level in 1974 was the Adventurer SE, not the Adventurer Sport. The Adventurer SE was always the top trim level any year it was offered, from 1971-1980. In 1981 the Royal name replaced the Adventurer name.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: D_C]
#2728015
12/29/19 02:41 PM
12/29/19 02:41 PM
Posts: 77 South East Ontario, Canada
Ramtough
Base Custom, slant 6, 3 sp std, hub caps, chrome front bumper, manual disc brake and manual steering. As for options any of them were available except outside bright work. The custom could have though a narrow(about 1" wide molding that followed the body line, 2 tone paint not required and a narrow molding around the back of the cab, only available though if 2 tone paint was ordered with roof color being different My dads 74 Custom had the side molding with the whole truck in Bronze met., 318, auto, PS, full wheel covers, painted rear step, and spare tire. Is there a definition or list of options, trim package, etc, that would be built into/included in a “Custom” vs “Adventurer” model, etc?
