Belt driven fuel pumps #2723845
12/13/19 08:45 PM
12/13/19 08:45 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
Which belt drive fuel pumps are you useing on alcohol I am running a carburetor
Re: Belt driven fuel pumps [Re: dragon] #2723849
12/13/19 09:12 PM
12/13/19 09:12 PM
The one the manufacturers recommend for your system scope up
If your using a carb made for alcohol I use a B.G. 400 pump on my S.P. car running E85 through a Holley Dominator converted to E85 by AJ at BG racing up
Re: Belt driven fuel pumps [Re: Cab_Burge] #2724001
12/14/19 02:49 PM
12/14/19 02:49 PM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
BLP makes a nice one that can be used with alcohol or gas by changing a spring.
