Re: 426 Hemi Rocker Stand Issue??????
[Re: A727Tflite]
#2973068
10/11/21 03:27 PM
10/11/21 03:27 PM
Posts: 1,672 Virginia
HemiStan
Virginia
I’ll look and see if I find the part numbers but it’s looks like you have the 2” stands. Sounds good! Thank you! Stan
[Re: rickseeman]
#2973070
10/11/21 03:30 PM
10/11/21 03:30 PM
HemiStan
Virginia
I assume they would have to be 2" rocker stands. I can't remember any other being different except D-5 and they are completely different.
I show 2" rocker gear casting numbers as 3614098 3614099 3614100 Interesting.... We might have another casting number to add to the batch of 2" rocker stands. 361409"6". Stan
[Re: HemiStan]
#2973403
10/12/21 12:45 PM
10/12/21 12:45 PM
Posts: 2,686 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Makes me wonder if when I got those numbers the 8 was really a 6. That would be a logical explanation.
2011 Drag Pak Challenger
[Re: rickseeman]
#2973407
10/12/21 12:46 PM
10/12/21 12:46 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
Maybe the stands you have are for the 1965/195 race only K heads They weren't different. I ASSUME they were based on the valve cover being different on the early K heads ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: rickseeman]
#2973625
10/12/21 05:37 PM
10/12/21 05:37 PM
HemiStan
Virginia
Makes me wonder if when I got those numbers the 8 was really a 6. That would be a logical explanation. I went back and looked at the stands. I am pretty sure the last digit is a “6” but as you can tell, that last number isn’t as clear as the others. Stan
[Re: HemiStan]
#2973634
10/12/21 06:10 PM
10/12/21 06:10 PM
Posts: 3,105 Michigan
A727Tflite
Makes me wonder if when I got those numbers the 8 was really a 6. That would be a logical explanation. I went back and looked at the stands. I am pretty sure the last digit is a “6” but as you can tell, that last number isn’t as clear as the others. Stan If you need 4 standard oiling stands maybe we can work something out. PM if interested.
[Re: A727Tflite]
#2973922
10/13/21 12:59 PM
10/13/21 12:59 PM
HemiStan
Virginia
Makes me wonder if when I got those numbers the 8 was really a 6. That would be a logical explanation. I went back and looked at the stands. I am pretty sure the last digit is a “6” but as you can tell, that last number isn’t as clear as the others. Stan If you need 4 standard oiling stands maybe we can work something out. PM if interested. PM Sent!! Stan
[Re: HemiStan]
#2974159
10/13/21 10:32 PM
10/13/21 10:32 PM
A727Tflite
Makes me wonder if when I got those numbers the 8 was really a 6. That would be a logical explanation. I went back and looked at the stands. I am pretty sure the last digit is a “6” but as you can tell, that last number isn’t as clear as the others. Stan If you need 4 standard oiling stands maybe we can work something out. PM if interested. PM Sent!! Stan ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
