Re: Indy valve covers [Re: cl440] #272325
04/23/09 10:48 AM
04/23/09 10:48 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Bubba, I have the same problem as you. The only thing I could come up with was pull one valve cover off and use a trans funnel from Advance to pur the oil down into the lifter galley. Maybe not the best idea but it beats spending 20 mins. trying to pour the oil in the small hole in the breather.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Indy valve covers [Re: MRMOPAR622] #272326
04/23/09 08:55 PM
04/23/09 08:55 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i just drilled & tapped the covers to fit -8 fittings. this way theres no oil dripping on the headers & making a mess. the valley plate also got drilled & put a capping fitting in there for adding oil. trying to get oil in thru the open covers is a pain as you know the oil is going leak out at the back of the head.
