Re: Remove clock knob?
[Re: SportF]
#2722972
12/10/19 02:16 PM
12/10/19 02:16 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
How to remove a clock knob from a '63 Plymouth B body dash. I know the shaft is threaded, but isn't there a collar, shaft, and a knob? Please advise. Thanks There is a "small" sleeve nut in the center of the knob,if the shaft is intact and the threaded end not broken,it's self explanatory..
[Re: SportF]
#2722999
12/10/19 03:28 PM
12/10/19 03:28 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
is easier to note being dissasembled... then you'll figure it out! hold the exterior piece ( knob itself ) while unscrewing the center nut with a tiny screwdriver
