Re: Bearing experts?? [Re: dvw] #2723096
12/10/19 09:57 PM
12/10/19 09:57 PM
ON
GTSocker Offline
GTSocker  Offline
ON
Since there is contact all the way around the whole bearing...
1 Had this been happening under power and or at RPM. That rod would be through the block. This is a low RPM occurrence,
2 the effected areas could just have less oil due to the delivery or from possibly bleed off.
3 The effected areas could also have less clearance...
Re: Bearing experts?? [Re: GTSocker] #2723113
12/10/19 10:49 PM
12/10/19 10:49 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Originally Posted by GTSocker
I'm guessing you are starving for oil on deceleration. Maybe rethink your oil pan and pick up??
I run on some pretty long tracks. I wouldn't think that would be a issue. I am never on the brakes hard. I suppose its possible though
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Bearing experts?? [Re: CoDart] #2723114
12/10/19 10:52 PM
12/10/19 10:52 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Originally Posted by CoDart
Whats your engine/turbo combo? Sounds like its making some decent steam for sure!
9.5-1 500" RB factory block. Mopar VI heads. EFI precision 114mm turbo.. It makes more power than the factory block can handle.. I was surprised the main bearings look so good.
Re: Bearing experts?? [Re: dvw] #2723116
12/10/19 11:01 PM
12/10/19 11:01 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Originally Posted by dvw
These are my questions. Why would the #3/4 rod and #3 main be hit the worst? Is the main web cracked? If there was lack of oil feed to the #3 main the #5 rod should show wear as well. #3/4 are not last in line for oil. What was the bearing clearance? Are the journals round and straight? Is the crank cracked?
Doug
Those are all questions that I don't have answers for yet. I haven't lifted the crank out yet. I don't recall the clearances but they were plasti gauged when I built it and within spec. Didn't check every journal but checked a few.. I swapped bearings out back in 12' when It ate a piston. They looked like new then.. Only change is the oil pan. Ive ran the same single line Milodon plate added to the Melling HV pump. Square Pick up is about 1/2" to 3/4" off the pan floor.
Re: Bearing experts?? [Re: HOTMOPR] #2723122
12/10/19 11:23 PM
12/10/19 11:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How deep is your pan(measured) that PU is a long way off the bottom
wave
Re: Bearing experts?? [Re: MR_P_BODY] #2723126
12/10/19 11:31 PM
12/10/19 11:31 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
5.5" deep Shoot I'll go measure the pick up depth
Re: Bearing experts?? [Re: HOTMOPR] #2723133
12/10/19 11:58 PM
12/10/19 11:58 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Ya the pick up is just under 3/4" off the bottom. I cant go much lower do to the roundness of the bottom of the pan. Atleast not without mods. The sump measures 9" front to back and 13" wide. total pan depth from rail to bottom is 5.5". The sump is about 3" deep
Re: Bearing experts?? [Re: HOTMOPR] #2723135
12/11/19 12:08 AM
12/11/19 12:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats a long ways off the bottom.. I'd mod the pan so you can be no more than a 1/4"off.. you
could be sucking in air
wave
Re: Bearing experts?? [Re: MR_P_BODY] #2723139
12/11/19 12:32 AM
12/11/19 12:32 AM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
on it.. up
Re: Bearing experts?? [Re: HOTMOPR] #2723187
12/11/19 09:37 AM
12/11/19 09:37 AM
an8sec70cuda Offline
Like DVW said, I'm interested to see if the crank passes the mag test.
The pickup needs to be a lot closer to the bottom of the pan.
Plastigage for checking clearances isn't even close. All it does is tell you if you have clearance or not, lol. Get a 2"-3" micrometer and a dial bore gauge.
Those Milodon sandwich plates aren't known for flowing real good. Not saying that's your issue, but I'd look into other options like using a Milodon cover on top of that HV pump.
CHIP
'06 GMC 2500HD LBZ Duramax
