Re: Bearing experts??
[Re: GTSocker]
#2723113
12/10/19 10:49 PM
12/10/19 10:49 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
I'm guessing you are starving for oil on deceleration. Maybe rethink your oil pan and pick up?? I run on some pretty long tracks. I wouldn't think that would be a issue. I am never on the brakes hard. I suppose its possible though
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: CoDart]
#2723114
12/10/19 10:52 PM
12/10/19 10:52 PM
HOTMOPR
Oakville, Wa
Whats your engine/turbo combo? Sounds like its making some decent steam for sure! 9.5-1 500" RB factory block. Mopar VI heads. EFI precision 114mm turbo.. It makes more power than the factory block can handle.. I was surprised the main bearings look so good.
[Re: dvw]
#2723116
12/10/19 11:01 PM
12/10/19 11:01 PM
HOTMOPR
Oakville, Wa
These are my questions. Why would the #3/4 rod and #3 main be hit the worst? Is the main web cracked? If there was lack of oil feed to the #3 main the #5 rod should show wear as well. #3/4 are not last in line for oil. What was the bearing clearance? Are the journals round and straight? Is the crank cracked? Doug Those are all questions that I don't have answers for yet. I haven't lifted the crank out yet. I don't recall the clearances but they were plasti gauged when I built it and within spec. Didn't check every journal but checked a few.. I swapped bearings out back in 12' when It ate a piston. They looked like new then.. Only change is the oil pan. Ive ran the same single line Milodon plate added to the Melling HV pump. Square Pick up is about 1/2" to 3/4" off the pan floor.
[Re: MR_P_BODY]
#2723126
12/10/19 11:31 PM
12/10/19 11:31 PM
HOTMOPR
Oakville, Wa
5.5" deep Shoot I'll go measure the pick up depth
[Re: HOTMOPR]
#2723133
12/10/19 11:58 PM
12/10/19 11:58 PM
HOTMOPR
Oakville, Wa
Ya the pick up is just under 3/4" off the bottom. I cant go much lower do to the roundness of the bottom of the pan. Atleast not without mods. The sump measures 9" front to back and 13" wide. total pan depth from rail to bottom is 5.5". The sump is about 3" deep
[Re: MR_P_BODY]
#2723139
12/11/19 12:32 AM
12/11/19 12:32 AM
HOTMOPR
Oakville, Wa
on it..
[Re: HOTMOPR]
#2723187
12/11/19 09:37 AM
12/11/19 09:37 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Like DVW said, I'm interested to see if the crank passes the mag test. The pickup needs to be a lot closer to the bottom of the pan. Plastigage for checking clearances isn't even close. All it does is tell you if you have clearance or not, lol. Get a 2"-3" micrometer and a dial bore gauge.
Those Milodon sandwich plates aren't known for flowing real good. Not saying that's your issue, but I'd look into other options like using a Milodon cover on top of that HV pump.
