Bearing experts??
#2722367
12/07/19 06:27 PM
12/07/19 06:27 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Any ideas what's going on here? Front to back. Lefty to right.. This is out of my 500" turbo motor . Stock 440 block stock caps. The mains look good except the thrust bearing. The thrust faces look pretty much untouched. The rear 4 rod bearings damage I would say probably from the junk that got pumped through it at the end. Just some scratching.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Bearing experts??
[Re: HOTMOPR]
#2722369
12/07/19 06:32 PM
12/07/19 06:32 PM
HOTMOPR
Oakville, Wa
Not sure how many passes it has but it hasn't been apart some 2011. Been running 12-16ish psi
[Re: HOTMOPR]
#2722373
12/07/19 06:39 PM
12/07/19 06:39 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
I would check the crank for run out to see on the all the main bearing surfaces to see if it is bent or not I don't like to see any run out at all on any of the mains EDITED, look real closely for cracks in the main webbing between the bottom of the block cylinder walls down into the main webbing also I'm not trying to alarm you but better to find it, any problems, now instead of running over the crankshaft later
[Re: Cab_Burge]
#2722379
12/07/19 06:49 PM
12/07/19 06:49 PM
HOTMOPR
Oakville, Wa
Ok thanks Cab. This motors race days are done. I am building a new short block for the race car. This 500 will be going in my 63 for street duty. unless the block is cracked.. lol. Ill pull the crank and get it checked too
[Re: Twostick]
#2722452
12/08/19 01:27 AM
12/08/19 01:27 AM
HOTMOPR
Oakville, Wa
ya there was a ton of build up around the dowel. Luckily it didt spin. Crank still looks great! Or great enough for me .. lol
[Re: HOTMOPR]
#2722579
12/08/19 04:43 PM
12/08/19 04:43 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
My best guess is you are starving it for oil on the launch. Middle sump pan? Oil climbs to the rear of the engine and splash oils the rear half of the rotating assy. Are you logging oil pressure?
[Re: TRENDZ]
#2722581
12/08/19 04:54 PM
12/08/19 04:54 PM
HOTMOPR
Oakville, Wa
Yes center sump road race pan. Running 8 quarts. All the baffles are cut out. Has a single line Milodon pickup. Logs show 70-75 psi whole run.
[Re: TRENDZ]
#2722652
12/08/19 09:35 PM
12/08/19 09:35 PM
TRENDZ
Milwaukee WI
Why is it apart? Were there symptoms? Im surprised the logs never showed a change.
[Re: TRENDZ]
#2722658
12/08/19 10:15 PM
12/08/19 10:15 PM
HOTMOPR
Oakville, Wa
Building a new short block. I was checking bearings after the beating this block has taken. This combo has been 138-140 mph in the 1/8th mile at 3550 pounds so it been making some power I was expecting main bearing damage but not much rod bearing issues. Was planning to throw a different cam and heads on it and roll some new bearing in it. Then run it in my street car.
[Re: HOTMOPR]
#2722659
12/08/19 10:20 PM
12/08/19 10:20 PM
HOTMOPR
Oakville, Wa
I did notice some light bearing material in my K&P when I was creeping up on 18 psi. So I turned it down for the last race. Assuming it was main bearing material. That's the main reason I pulled caps. As for logs there was zero change in oil pressures throughout the year.
[Re: HOTMOPR]
#2722872
12/10/19 04:18 AM
12/10/19 04:18 AM
Cab_Burge
I think the #3 main bearing trash mostly went into #4 rod and some of that material may have been caught a tiny bit by #3 rod I'm really surprised that none of the main bearing trash from the center main bearings wasn't wash into #5 rod bearing also Did the motor have at least .0040 or more thrust clearances new? Was #3 main bearing straight with no taper front to rear on the clearances? I've seen between .0002 to .0004 taper on some of the new main bearings with block that had been align honed with new main caps and studs
