Re: Are there any "small" OEM BB crank pullies?
[Re: BSB67]
#2722516
12/08/19 12:29 PM
12/08/19 12:29 PM
BradH
Not sure what diameter the Moroso is, only that it says a 30% reduction in pulley speed, IIRC. My brain hasn't shifted into calculator mode to reverse-engineer the diameter. .
Reduction will be directly proportional to diameter. Diameter? 70% of 6.25 is only about 4.3... unless the standard factory pulley is actually 7+".
[Re: AndyF]
#2722518
12/08/19 12:34 PM
12/08/19 12:34 PM
BradH
At 3500 rpm cruise you could use a smaller pulley without any trouble. My guess is that the factory designed the water pump to be really effective in the 2000 to 2500 rpm range so you are probably overdriving your pump a little right now. A smaller crank pulley might improve cooling on your setup. I was thinking pretty much the same standard RPM range; 30% slower than 3500 is 2450...
[Re: BradH]
#2722534
12/08/19 01:00 PM
12/08/19 01:00 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: HOTMOPR]
#2722560
12/08/19 02:39 PM
12/08/19 02:39 PM
Posts: 31,029 Oregon
AndyF
[Re: BradH]
#2722565
12/08/19 03:06 PM
12/08/19 03:06 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
Reduction will be directly proportional to diameter. Circumference, not diameter. 70% of 6.25 is only about 4.3... And 70% of circumference still results in 4.3" diameter. Pulley speed, circumference and diameter are all proportional. So either Moroso made an error, or their pulley is 4.3, or they started with a different pulley diameter for the claimed 70%. FWIW, the crank pulleys I have here range from 6.5 to 7.25.
[Re: AndyF]
#2722589
12/08/19 05:35 PM
12/08/19 05:35 PM
Posts: 421 montana
BANDIT
montana
Years ago, MP used to sell March pulley sets. When they quit, they were selling them off cheap. I picked up a few different sets with that smaller lower pulley and have used it on a couple of street cars. They are quality pieces.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: BANDIT]
#2722730
12/09/19 11:51 AM
12/09/19 11:51 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I used to run the small Moroso crank pulley w/ a belt driven water pump setup on my 14:1 Indy headed 440. That was years ago in my cuda, ran 10.40s, but ran great on the street. No cooling issues whatsoever, just went through a lot of C12, lol.
