Original distributors and vaccumm advance types #2720695
12/01/19 05:03 PM
12/01/19 05:03 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hello,
I am currently restoring all the dual point distributors for my cars and I see that some of them have this type of vac advance:
https://www.ebay.com/itm/1968-Plymouth-Dodge-NOS-MOPAR-318-CI-Engine-Distributor-Vacuum-Advance/254334581130?hash=item3b3785b98a:g:Na4AAOSwPPFdR45b
while some others have this type:
https://www.ebay.com/itm/Vacuum-Advance-Control-Pod-VC184-for-Mopar-Small-Block-Electronic-Distributor/143341368959?epid=75431013&hash=item215fcfb67f:g:ekwAAOSwUPJdPlaK
was that a year change or whats the deal? What is correct for each application/year????
Re: Original distributors and vaccumm advance types [Re: domingo] #2720698
12/01/19 05:08 PM
12/01/19 05:08 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
here are the 2 types i am talking about....
Re: Original distributors and vaccumm advance types [Re: domingo] #2720716
12/01/19 05:53 PM
12/01/19 05:53 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Left 70 and later,right 69 back.Also,what you show are not dual point Prestolite,the Prestolite dual point does not use the advance with the locator tabs for the cap,the top advance you show is a 68 318 single point.
Re: Original distributors and vaccumm advance types [Re: 62maxwgn] #2720835
12/02/19 09:33 AM
12/02/19 09:33 AM
VA
dragon slayer Offline
VA
I will add to pay attention to stamped advance on arm, actual final bend length on arm at hole. So match what you have if these are original. Attached is picture. Notice two in center. The short extension at hole is DP. Longer extension at hole is the SP AL/Prestolite VC. Also save your springs and washers from the old, you will need them.
Re: Original distributors and vaccumm advance types [Re: dragon slayer] #2720865
12/02/19 12:45 PM
12/02/19 12:45 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Also note that many early 70 distributors were built using the 69 style vacuum advance unit, I've seen quite a few original 70 Hemis and six packs this way.
Re: Original distributors and vaccumm advance types [Re: ScottSmith_Harms] #2726337
12/23/19 09:34 AM
12/23/19 09:34 AM
NC
Sixt8Chrgr Offline
Sixt8Chrgr  Offline
NC
Would an March 11th built AAR possibly have the 69 VAC?
