A body 8 3/4 Axle length #2719854
11/27/19 08:18 PM
11/27/19 08:18 PM
Fargo ND
moparphilll Offline OP
Fargo ND
does anyone have a measurement?
I.m thinking my bearings got pressed on to far...
Re: A body 8 3/4 Axle length [Re: moparphilll] #2719904
11/27/19 11:38 PM
11/27/19 11:38 PM
It is not possible to press thee axle bearings on too far, the axle register stops the inner bearing race scope You can NOT press it on to far! You can press it on not all the way though work
What makes you think you have a problem with that axle and bearing?
Re: A body 8 3/4 Axle length [Re: Cab_Burge] #2719923
11/28/19 01:18 AM
11/28/19 01:18 AM
Fargo ND
Fargo ND
when installing the axles they bottom out against the pumpkin and stick out about 3/4" on both sides
Re: A body 8 3/4 Axle length [Re: moparphilll] #2719938
11/28/19 03:05 AM
11/28/19 03:05 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Stock 5 x 4" bolt pattern A body axles measure 27.7".
Looks like the sure-grip side gear/clutch hub splines are mis-aligned or the inner axle seals are not driven into the housing far enough.
Re: A body 8 3/4 Axle length [Re: DoctorDiff] #2719941
11/28/19 03:25 AM
11/28/19 03:25 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
If its a Clutch Sure Grip, your inside "Axle shaft Alignment Spacer" pins may be popped out of their holes deep inside the center. I have seen these pins fall out and get stuck in and the axles can not go all the way in.
These pins are required so that when you turn the axle adjuster that is on one side (I think left axle) it will push the other axle out so both axles end plays are even.
Pop the pumpkin out and look inside to the alignment pins.
http://www.moparts.org/Tech/Archive/axle/13.html
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: A body 8 3/4 Axle length [Re: moparphilll] #2720192
11/29/19 02:10 AM
11/29/19 02:10 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
looks like you used the green bearings , soo you have to remove the axel spacer pin in the carrier !
if you have no adjuster for end play on the one axel you got green bearings !
Re: A body 8 3/4 Axle length [Re: calrobb2000] #2720388
11/30/19 06:45 AM
11/30/19 06:45 AM
Fargo ND
Fargo ND
Is the axle spacer pin in all carriers? (photo) please
Re: A body 8 3/4 Axle length [Re: moparphilll] #2720397
11/30/19 09:36 AM
11/30/19 09:36 AM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
No as far as I know only on the pre 69 suregrips
Re: A body 8 3/4 Axle length [Re: GVH] #2720453
11/30/19 02:41 PM
11/30/19 02:41 PM
1969 was the change over year(some early cars had the clutch types) on the posi units from the Dana clutch type with the center pins to the spring type cup and cone style without them. The later style has springs inside that can be seen from the hole in the carrier. The clutch style carriers are two piece that bolt together and the alter style is cast in one piece with one side open to put the interior parts inside them wrench
OP, you can use a flashlight from one side of the rear end housing to look inside it to see if the axle adjusting end pins are in there or not. If there is a hole in the center with no parts laying inside the splined part of the posi unit on that side you may need to look on the other side shruggy
if no hole in the center block of the posi unit you have the later style posi scope
Re: A body 8 3/4 Axle length [Re: Cab_Burge] #2720484
11/30/19 05:49 PM
11/30/19 05:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'm betting Doc Diff's analysis is correct, misaligned splines in the side gear.
Re: A body 8 3/4 Axle length [Re: John_Kunkel] #2720550
12/01/19 01:28 AM
12/01/19 01:28 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
ALL 8.75 carriers originally came with a center thrust spacer installed. If you are running a stock housing, stock axles, stock brakes and snap-ring style Green bearings, it does NOT need to be removed.
Re: A body 8 3/4 Axle length [Re: DoctorDiff] #2720563
12/01/19 06:30 AM
12/01/19 06:30 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Either the splines, or I'm thinking the topicstarter mistakes 'bottoming out' with the bearing's outside O-ring trying to enter the actual housing.
Some grease on the O-ring and a few light taps around the bearing or axle-flange should pop it right in.
Re: A body 8 3/4 Axle length [Re: BigBlockMopar] #2721484
12/04/19 09:24 PM
12/04/19 09:24 PM
Fargo ND
Fargo ND
Ive come to the conclusion that the housing was made or cut down and was made to short.. I took rubber seals off bearings and still bottoming out with about a 1/2 to go.. going to try find an original A body 8 3/4 axle and see if same problem,,,
Re: A body 8 3/4 Axle length [Re: moparphilll] #2721536
12/04/19 11:56 PM
12/04/19 11:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are you sure the clutch hub splines are lined up?
Re: A body 8 3/4 Axle length [Re: moparphilll] #2721684
12/05/19 01:49 PM
12/05/19 01:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
What is the housing width flange-to-flange? Stock A-body is 52 5/8".
Re: A body 8 3/4 Axle length [Re: John_Kunkel] #2721867
12/05/19 09:58 PM
12/05/19 09:58 PM
Fargo ND
Fargo ND
Mine is 51"
Re: A body 8 3/4 Axle length [Re: John_Kunkel] #2721916
12/06/19 02:18 AM
12/06/19 02:18 AM
iagree That is what I remember measuring across the front with no third member in the housing from the outer axle bearing flange to the other outside flange wrench
Re: A body 8 3/4 Axle length [Re: Cab_Burge] #2721923
12/06/19 05:44 AM
12/06/19 05:44 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Hard to imagine someone spending the money, time and energy to cut just 1.625" off a rear end. Most get chopped 3+ inches.
65 Formula S Cuda
