A body 8 3/4 Axle length
#2719854
11/27/19 08:18 PM
11/27/19 08:18 PM
Posts: 2,578 Fargo ND
moparphilll
Fargo ND
does anyone have a measurement?
I.m thinking my bearings got pressed on to far...
Re: A body 8 3/4 Axle length
[Re: moparphilll]
#2719904
11/27/19 11:38 PM
11/27/19 11:38 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
It is not possible to press thee axle bearings on too far, the axle register stops the inner bearing race ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) You can NOT press it on to far! You can press it on not all the way though ![work work](/ubbthreads/images/graemlins/custom/work.gif) What makes you think you have a problem with that axle and bearing?
[Re: Cab_Burge]
#2719923
11/28/19 01:18 AM
11/28/19 01:18 AM
moparphilll
Fargo ND
when installing the axles they bottom out against the pumpkin and stick out about 3/4" on both sides
[Re: DoctorDiff]
#2719941
11/28/19 03:25 AM
11/28/19 03:25 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
If its a Clutch Sure Grip, your inside "Axle shaft Alignment Spacer" pins may be popped out of their holes deep inside the center. I have seen these pins fall out and get stuck in and the axles can not go all the way in. These pins are required so that when you turn the axle adjuster that is on one side (I think left axle) it will push the other axle out so both axles end plays are even. Pop the pumpkin out and look inside to the alignment pins. http://www.moparts.org/Tech/Archive/axle/13.html
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: GVH]
#2720453
11/30/19 02:41 PM
11/30/19 02:41 PM
Cab_Burge
No as far as I know only on the pre 69 suregrips 1969 was the change over year(some early cars had the clutch types) on the posi units from the Dana clutch type with the center pins to the spring type cup and cone style without them. The later style has springs inside that can be seen from the hole in the carrier. The clutch style carriers are two piece that bolt together and the alter style is cast in one piece with one side open to put the interior parts inside them ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif) OP, you can use a flashlight from one side of the rear end housing to look inside it to see if the axle adjusting end pins are in there or not. If there is a hole in the center with no parts laying inside the splined part of the posi unit on that side you may need to look on the other side ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) if no hole in the center block of the posi unit you have the later style posi ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: Cab_Burge]
#2720484
11/30/19 05:49 PM
11/30/19 05:49 PM
Posts: 26,008 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I'm betting Doc Diff's analysis is correct, misaligned splines in the side gear.
[Re: moparphilll]
#2721684
12/05/19 01:49 PM
12/05/19 01:49 PM
John_Kunkel
Rio Linda, CA
Ive come to the conclusion that the housing was made or cut down and was made to short.. What is the housing width flange-to-flange? Stock A-body is 52 5/8".
[Re: John_Kunkel]
#2721916
12/06/19 02:18 AM
12/06/19 02:18 AM
Cab_Burge
Ive come to the conclusion that the housing was made or cut down and was made to short.. What is the housing width flange-to-flange? Stock A-body is 52 5/8". ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) That is what I remember measuring across the front with no third member in the housing from the outer axle bearing flange to the other outside flange ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif)
[Re: Cab_Burge]
#2721923
12/06/19 05:44 AM
12/06/19 05:44 AM
Dave_J
Auburn WA
Hard to imagine someone spending the money, time and energy to cut just 1.625" off a rear end. Most get chopped 3+ inches.
