O rings for big block oil pump #2719562
11/26/19 08:30 PM
11/26/19 08:30 PM
California
mickm Offline OP
mickm  Offline OP
California
Does anyone have the specs on these o rings, or where I can get some? I'm missing the small O ring, but it would be nice to have some spares, for a case just like this!
Re: O rings for big block oil pump [Re: mickm] #2719600
11/26/19 11:49 PM
11/26/19 11:49 PM
Are you talking about the small thin one that goes around the pump snout that slides up into the block or the other small one between the pump cover and the pump body?
Re: O rings for big block oil pump [Re: mickm] #2719613
11/27/19 12:36 AM
11/27/19 12:36 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Anyone that make/sells replacement hydraulic hoses and components will have them.
Re: O rings for big block oil pump [Re: Cab_Burge] #2719633
11/27/19 03:25 AM
11/27/19 03:25 AM
California
mickm Offline OP
mickm  Offline OP
California
pump cover and body.
Re: O rings for big block oil pump [Re: mickm] #2719634
11/27/19 03:30 AM
11/27/19 03:30 AM
I may have a few new ones out in the shop, I'll try and dig one out and measure it with a dial caliper in the morning and post the size on here before noon.
Re: O rings for big block oil pump [Re: mickm] #2719668
11/27/19 09:49 AM
11/27/19 09:49 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Rich H.
Esse Quam Videri
Re: O rings for big block oil pump [Re: ZIPPY] #2719686
11/27/19 10:48 AM
11/27/19 10:48 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
2011 Drag Pak Challenger
Re: O rings for big block oil pump [Re: ZIPPY] #2719720
11/27/19 12:48 PM
11/27/19 12:48 PM
California
mickm Offline OP
mickm  Offline OP
California
Thanks for finding and posting those, do appreciate it. neither of them have the one I need.
It's the smaller one on the left of the "Seal Ring".
Re: O rings for big block oil pump [Re: mickm] #2719724
11/27/19 01:09 PM
11/27/19 01:09 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Looks like Milodon 21591 might have it.
The MoPar pn is 2084 355
I think it's called an oil pickup seal, even though the pickup itself screws into the block I think this O ring seals the passage from the pickup to the pump rotors.
Unfortunately, I got rid of all my B/RB stuff a long time ago so I can't measure anything out for you.
Re: O rings for big block oil pump [Re: Sniper] #2719728
11/27/19 01:19 PM
11/27/19 01:19 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Like I posted above,"Anyone that make/sells replacement hydraulic hoses and components will have them",been getting them for years ! twocents
Re: O rings for big block oil pump [Re: 62maxwgn] #2719738
11/27/19 01:47 PM
11/27/19 01:47 PM
California
mickm Offline OP
mickm  Offline OP
California
Yes, but if I don't know the size, I don't know what to ask for. I can approximate off of the grove in the casting, but would rather have something specific.
Re: O rings for big block oil pump [Re: Sniper] #2719741
11/27/19 01:53 PM
11/27/19 01:53 PM
California
mickm Offline OP
mickm  Offline OP
California
Yes, the Milodon is it. All I can say is thanks for taking the slack of my laziness. I did search Summit earlier, but just didn't drill down correctly. I started from scratch and this came up.
Re: O rings for big block oil pump [Re: mickm] #2719747
11/27/19 02:12 PM
11/27/19 02:12 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
All I ask is that you post the sizes for everyone to have, lol.
Re: O rings for big block oil pump [Re: mickm] #2719749
11/27/19 02:20 PM
11/27/19 02:20 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Do you have the pump off ? If you do take it with you !
As close as I can get,OD 0.800,diameter 0.100
Re: O rings for big block oil pump [Re: 62maxwgn] #2719757
11/27/19 02:42 PM
11/27/19 02:42 PM
California
mickm Offline OP
mickm  Offline OP
California
Good point, helps if I tell the whole story. This is a pump that I've had around for a while, and want to use on an engine. It has the large o ring, but not the small. Seeing as how it is missing, I'd like to replace it, but also have a spare around. Never hurts...
Re: O rings for big block oil pump [Re: Sniper] #2719758
11/27/19 02:43 PM
11/27/19 02:43 PM
California
mickm Offline OP
mickm  Offline OP
California
Will do! Once I get hold of one, I'll do that!
Now all I have to do is remember to do it!
Re: O rings for big block oil pump [Re: mickm] #2722111
12/06/19 07:54 PM
12/06/19 07:54 PM
California
mickm Offline OP
mickm  Offline OP
California
OD of the whole O ring is 13/16.
OD of the material is 5/64.
This is from the Milodon kit.
Re: O rings for big block oil pump [Re: mickm] #2722208
12/07/19 12:40 AM
12/07/19 12:40 AM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
Try a 2-017 O-Ring. Any decent hyd hose shop should be able to get you taken care of. May even be able to hit a local hardware store for them.
It should cost you about $0.20 or less for one.
Parker O-Ring size guide for 2-xxx sizes.
https://www.parker.com/literature/O-Ring%20Division%20Literature/2-xxx%20sizes.pdf
Re: O rings for big block oil pump [Re: jb500] #2722214
12/07/19 01:27 AM
12/07/19 01:27 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
From the Milodon website on BB Mopar oil pumps:
"NOTE: This pump does not use stock Chrysler O-ring around gear set. Special supplied O-ring must be used, also available in system rebuild kit #21590.
21815"
https://www.milodon.com/oil-system/oil-pumps.php
Floyd Lippencott IV
Re: O rings for big block oil pump [Re: mr_340] #2722235
12/07/19 09:43 AM
12/07/19 09:43 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
21815"
We're not talking about a Milodon oil pump.
The gasket kit, 21591, info from Milodon:
Quote
CHRYSLER OIL SYSTEM GASKET & O-RING KIT
Includes oil pump to block, pressure regulator assembly, old style oil filter adapter gasket, oil pump and pick-up O-rings for Milodon Oil Systems or any other Chrysler Hemi and Wedge oil pumps. Contains all components necessary
