O rings for big block oil pump
#2719562
11/26/19 08:30 PM
11/26/19 08:30 PM
Posts: 4,179 California
mickm
California
Does anyone have the specs on these o rings, or where I can get some? I'm missing the small O ring, but it would be nice to have some spares, for a case just like this!
Re: O rings for big block oil pump
[Re: mickm]
#2719600
11/26/19 11:49 PM
11/26/19 11:49 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
Are you talking about the small thin one that goes around the pump snout that slides up into the block or the other small one between the pump cover and the pump body?
[Re: Cab_Burge]
#2719633
11/27/19 03:25 AM
11/27/19 03:25 AM
mickm
California
Are you talking about the small thin one that goes around the pump snout that slides up into the block or the other small one between the pump cover and the pump body? pump cover and body.
[Re: mickm]
#2719634
11/27/19 03:30 AM
11/27/19 03:30 AM
Cab_Burge
I may have a few new ones out in the shop, I'll try and dig one out and measure it with a dial caliper in the morning and post the size on here before noon.
[Re: ZIPPY]
#2719720
11/27/19 12:48 PM
11/27/19 12:48 PM
mickm
California
Thanks for finding and posting those, do appreciate it. neither of them have the one I need. It's the smaller one on the left of the "Seal Ring".
[Re: Sniper]
#2719741
11/27/19 01:53 PM
11/27/19 01:53 PM
mickm
California
Looks like Milodon 21591 might have it.
The MoPar pn is 2084 355
I think it's called an oil pickup seal, even though the pickup itself screws into the block I think this O ring seals the passage from the pickup to the pump rotors.
Unfortunately, I got rid of all my B/RB stuff a long time ago so I can't measure anything out for you. Yes, the Milodon is it. All I can say is thanks for taking the slack of my laziness. I did search Summit earlier, but just didn't drill down correctly. I started from scratch and this came up.
[Re: mickm]
#2719749
11/27/19 02:20 PM
11/27/19 02:20 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Like I posted above,"Anyone that make/sells replacement hydraulic hoses and components will have them",been getting them for years ! Yes, but if I don't know the size, I don't know what to ask for. I can approximate off of the grove in the casting, but would rather have something specific. Do you have the pump off ? If you do take it with you ! As close as I can get,OD 0.800,diameter 0.100
[Re: 62maxwgn]
#2719757
11/27/19 02:42 PM
11/27/19 02:42 PM
mickm
California
Like I posted above,"Anyone that make/sells replacement hydraulic hoses and components will have them",been getting them for years ! Yes, but if I don't know the size, I don't know what to ask for. I can approximate off of the grove in the casting, but would rather have something specific. Do you have the pump off ? If you do take it with you ! Good point, helps if I tell the whole story. This is a pump that I've had around for a while, and want to use on an engine. It has the large o ring, but not the small. Seeing as how it is missing, I'd like to replace it, but also have a spare around. Never hurts...
[Re: Sniper]
#2719758
11/27/19 02:43 PM
11/27/19 02:43 PM
mickm
California
All I ask is that you post the sizes for everyone to have, lol. Will do! Once I get hold of one, I'll do that! Now all I have to do is remember to do it!
[Re: jb500]
#2722214
12/07/19 01:27 AM
12/07/19 01:27 AM
Posts: 3,505 DFW
mr_340
DFW
From the Milodon website on BB Mopar oil pumps: "NOTE: This pump does not use stock Chrysler O-ring around gear set. Special supplied O-ring must be used, also available in system rebuild kit #21590. 21815" https://www.milodon.com/oil-system/oil-pumps.php
Floyd Lippencott IV
[Re: mr_340]
#2722235
12/07/19 09:43 AM
12/07/19 09:43 AM
Posts: 6,306 nowhere
Sniper
nowhere
From the Milodon website on BB Mopar oil pumps: "NOTE: This pump does not use stock Chrysler O-ring around gear set. Special supplied O-ring must be used, also available in system rebuild kit #21590. 21815" https://www.milodon.com/oil-system/oil-pumps.php We're not talking about a Milodon oil pump. The gasket kit, 21591, info from Milodon: CHRYSLER OIL SYSTEM GASKET & O-RING KIT
Includes oil pump to block, pressure regulator assembly, old style oil filter adapter gasket, oil pump and pick-up O-rings for Milodon Oil Systems or any other Chrysler Hemi and Wedge oil pumps. Contains all components necessary
