Re: Push rod question
[Re: 6PAX]
#2719174
11/25/19 02:13 PM
11/25/19 02:13 PM
Posts: 2,869 Pattison Texas
CSK
Pattison Texas
Is it necessary to pre-oil new push rods before installing them? I installed a new set of push rods along with the rocker arm assemblies on a new engine I am putting together (my first) and a friend of mine asked if I pre-oiled the push rods by dunking them in oil. I didn't as I hadn't heard of this. I lubed the ends with assembly grease and am going to pre-oil the motor with a priming rod so I don't really understand the point in dunking them in oil. Is there any need to do as he suggested or will it be O.K. as-is? It took some time to get all of the rocker arms set properly so I would hate to have to take them all off to get the push rods out just to dunk them in oil but I will if I have to. I also like to roll the motor while priming the oil pump, that way it oils the top end.
[Re: sam64]
#2719193
11/25/19 02:55 PM
11/25/19 02:55 PM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
I would say if you lubed the ends you are good to go.
[Re: an8sec70cuda]
#2719227
11/25/19 04:43 PM
11/25/19 04:43 PM
RapidRobert
On a side note a BB oils the rockers when the #8 and the #6 cyls are at TDC and a non magnum SB oils the pass rockers at 90 (1/4) turn BTDC #1 compression and the driver side rockers oil at 20 ATDC #6 compression
[Re: RapidRobert]
#2719234
11/25/19 05:09 PM
11/25/19 05:09 PM
CSK
Pattison Texas
On a side note a BB oils the rockers when the #8 and the #6 cyls are at TDC and a non magnum SB oils the pass rockers at 90 (1/4) turn BTDC #1 compression and the driver side rockers oil at 20 ATDC #6 compression Thanks RR, I had forgotten the deg where it oils.
[Re: RapidRobert]
#2719287
11/25/19 07:58 PM
11/25/19 07:58 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
On a side note a BB oils the rockers when the #8 and the #6 cyls are at TDC and a non magnum SB oils the pass rockers at 90 (1/4) turn BTDC #1 compression and the driver side rockers oil at 20 ATDC #6 compression if you groove the # 4 cam journal the width of the oil hole and .030 deep in the cam it will oil the rocker shafts full time A must do on any motor running a solid roller cam or any other cam that needs for or has 400+ Lbs. valve spring pressure open The extra oiling will help cool the valve springs making them live longer
