Re: Actual weight of fiberglass hood vs steel
[Re: hemienvy]
#2719361
11/26/19 01:45 AM
11/26/19 01:45 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
OK appreciate it much gents. I remember reading on here about manufacturers, think it was Fiberglass Trends or AAR or Glasstek that was the best quality ? NOT Unlimited. I believe any fiberglass part may not fit perfect . In my case I did buy a cowl hood for my 70 cuda from Unlimited. It was shipped very quick by truck freight in a big box. Quality wise I found all the ranting about poor quality Unlimited products was completely false. The top surface was smooth with no pits or waves, It fit square in the hood opening with the proper gap along the front and along the sides of the fenders. Contour was even along the top of the fenders . All that was needed as with all is a light sanding ,primer and ready for paint. Maybe they made a mistake and built something right, mine was right.
[Re: J_BODY]
#2719395
11/26/19 09:46 AM
11/26/19 09:46 AM
Posts: 13,408 Marion, South Carolina [><]
an8sec70cuda
I have a 5" tall Glasstek cowl hood on my '70 cuda. It is a very nice quality bolt on hood...been on the car since 2003. I haven't weighed it, but I'd say it might save 25 lbs. from the stock dual scoop hood. Just a guess. It is definitely no lightweight piece. Used to have a piece of crap MAS lift off 6 pack hood on the car and it was WAYYYY lighter. Like I said though, it was a flimsy piece of crap.
[Re: hemienvy]
#2719459
11/26/19 01:26 PM
11/26/19 01:26 PM
Posts: 22,749 Bitopia
jcc
Bitopia
"JCC, the magic question: Who makes a CF '70 Cuda bolt-on hood, and how much ?" The question really should be, who is willing to make a CF hood? The molds are interchangeable. The cost is not as much higher then most think, material cost wise,its affordable, but CF often is like buying anything "marine", price doubles... One big difficulty with CF is if the customer wants the "CF look", that becomes difficult, and in small production runs, incurs a number of cosmetic "seconds" to get the CF lay/pattern right:. If a painted finish is the goal, makes a simple layup, with all the benefits. Additionally because of the increase cure time of epoxy over polyester resin, turn around time on the mold is extended somewhat, Biggest problem that i see, shops are "afraid", and they shouldn't be. I have switched over to CF, and will likely never go back. Don't mean to mislead anybody, I do it only as a hobby. I know i only beat around the bush on your question.
[Re: jcc]
#2719551
11/26/19 08:14 PM
11/26/19 08:14 PM
Posts: 30,505 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
No matter what, it's worth it IMO in every case.
I do a lot of my own fiberglass, I have switched over to Carbon fiber/epoxy, a superior composite in many ways, it's not that much more expensive and the result is so worth it.
I think my 62 Lancer CF/Kevlar/sandwich hood weighs 11;bs?
Very Interesting jcc ..... I'm probably going to be shelving my CarrotVan project for a 61-2 4 door or wagon .... post a pic of that hood if you would
[Re: J_BODY]
#2719587
11/26/19 10:38 PM
11/26/19 10:38 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Our old VFN hood with a Harwood cowl attached was 36lb..... granted remembering the structure it may have been able to have hinges attached to it. It was a pita (like most lift offs) to remove by yourself. This pict is my Unlimited Products race weight hood. It’s 14lb with paint and Quik latches. Side gaps a bit wide, but I prefer that as it eases install. No complaints and their bumper fit great too! Did you use their bumper brackets or make your own? What color is that bumper??
Brian Hafliger
[Re: an8sec70cuda]
#2719699
11/27/19 11:33 AM
11/27/19 11:33 AM
Posts: 277 MN
Willie68coronet
MN
I have a 5" tall Glasstek cowl hood on my '70 cuda. It is a very nice quality bolt on hood...been on the car since 2003. I haven't weighed it, but I'd say it might save 25 lbs. from the stock dual scoop hood. Just a guess. It is definitely no lightweight piece. Used to have a piece of crap MAS lift off 6 pack hood on the car and it was WAYYYY lighter. Like I said though, it was a flimsy piece of crap. Lol, I know what you mean about the MAS. I had to add a hood pin in the center to keep the hood from looking like it'd break at over 40mph. With that said though, I love my MAS hood, been on since 2003 or so. It's a feather weight and easy to remove, I need to find a someone to make the scoop taller now for dominator clearance now.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: dOc …]
#2719715
11/27/19 12:26 PM
11/27/19 12:26 PM
jcc
Bitopia
Very Interesting jcc ..... I'm probably going to be shelving my CarrotVan project for a 61-2 4 door or wagon .... post a pic of that hood if you would I'll dig some pics up after Turkey, Happy Thanksgiving
