Re: Standard-port 493-512 builds?
[Re: BradH]
#2718697
11/23/19 05:15 PM
11/23/19 05:15 PM
fast68plymouth
So. Burlington, Vt.
With what is available for heads these days, the only way I can see a std port stroker combo being the preferred choice is if for some reason the big single plane manifold just doesn’t fit in well with the rest of your plans/combo.
As in........you want to run milder gearing, low-ish stall speed, a lower compression ratio, etc....... and along with those items comes a milder cam with a lower rpm operating range.
But if you’re trying to “make some power”, and are going to build a motor in the 500+ ci range, and are okay with running the appropriate support pieces....... I’d just skip right past all the std port stuff.
And then....... there will be those middle-of-the-road combos where the choice of std or MW isn’t all that cut and dried.
[Re: fast68plymouth]
#2718709
11/23/19 05:53 PM
11/23/19 05:53 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
Not that my junk is very fast but, I have the max W ports 512cid & HAD the SP Indy intake & 3.54 gear & it had LOTS of low rpm TQ, others said ports would be to large, would it run better with 440 size ports ? dont know, but not going to try it. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
[Re: AndyF]
#2718710
11/23/19 06:00 PM
11/23/19 06:00 PM
fast68plymouth
So. Burlington, Vt.
The higher effort 6bbl FAST motors were around 625hp with ex manifolds and 2.5” exhaust pipe....... ported 906 heads. No vacuum pump, stock Hemi style oil pan, non-oxygenated fuel.
Take one of those builds, use a race oriented single plane intake, add headers, and a cam to take advantage of the better intake and exhaust....... should be worth at least 50hp...... so that would put you at 675hp....... with better heads you should be able to find another 25hp...... which would put it around 700hp. Good pan, vac pump, q16....... should add even more.
[Re: Clanton]
#2718734
11/23/19 08:12 PM
11/23/19 08:12 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My last trip to BIR i saw what i thought was impossible. A fellow racer i have talked to a few times ran numbers i thought were impossible. His combo; 2500 lb race wieght Cuda. 540 with max ported SR heads, pg trans. Q16 fuel. HE RAN 8.37! I pitted next to him so i had a good look at the car. Obviously this was an all out build of sorts, not your joe average bracket motor. But still, 8.37? Impressive!! The Wallace calculater says 842 hp on that run with over 2200 DA. Granted, the heads were opened up to max wedge size, but still use rockers for the SR heads so it gives you an idea of what can be done. He said he shifted at 7400!
[Re: gregsdart]
#2718752
11/23/19 10:02 PM
11/23/19 10:02 PM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
Brad , Some are aware i went down this route , 505 cnc stealth heads . Stock port size . I knew port was too small , not much more than a reasonable sbc head , so i traded off with duration . Dwayne wasnt a fan , too rowdy , Billy got it . But i chose it and daily drive it . Best et was 10.50 on the brakes , but solid low 10.50s . Which was my goal . Drive to track , swap rear tyres and air cleaner and race . So good easy power using a solid ft cam , motor was only shifted @6000 . Won track championship with that motor . Just my 2 cents
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
#2718761
11/23/19 10:58 PM
11/23/19 10:58 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I just finished a customers 493 low deck build...TF 240 heads, Weiand dual plane intake, 850 carb, 10.2:1, hyd. cam with around .580 lift and 240's @ ,050, on our dyno it made 596HP @ 5700rpm and 608TQ @ 4400rpm.
Brian Hafliger
#2718771
11/24/19 12:29 AM
11/24/19 12:29 AM
tex013
Sydney,Australia
Yep , stock port size Had Victor with a prosystems hp1000 4150 carb . Also tried adapter and 4500 , then super victor , stock port , and 1050 . Adapter gave poor result , AFR was all over the place . Super victor was better , more consistant et/mph . No other changes . Andys intake gasket wings were great when doing this as were the Superformance thinner gaskets . The TF270 i then changed to were worth .25 et and 2-3mph . I opened the super victor up to suit the max wedge port . I really need to have the stealth heads tubed on a couple of headbolts where they cracked through into the intake port , Then sell them off Tex
[Re: BradH]
#2718775
11/24/19 01:29 AM
11/24/19 01:29 AM
BradH
Hypothetical scenario:
Take all the top end parts of a 680 HP / 600 torque 3.75-stroke combination with standard Victor heads.
Put them on a 500"-ish short block and keep the CR in pump gas territory... probably bump up the cam for the extra cubes.
What's the likely end result?
EDIT: I'm very happy with the my 3.75-stroke combination and it's a really good match for my car. I'm describing mine because it's a better example of what I was trying to ask than I think how most people understood my question.
[Re: BradH]
#2718777
11/24/19 01:48 AM
11/24/19 01:48 AM
Posts: 43,292 Bend,OR USA
Cab_Burge
[Re: Brian Hafliger]
#2718778
11/24/19 02:14 AM
11/24/19 02:14 AM
Posts: 31,074 Oregon
AndyF
I just finished a customers 493 low deck build...TF 240 heads, Weiand dual plane intake, 850 carb, 10.2:1, hyd. cam with around .580 lift and 240's @ ,050, on our dyno it made 596HP @ 5700rpm and 608TQ @ 4400rpm. Sounds roughly the same as what I'd expect on the dyno here. I've never used the Weiand dual plane intake, I assume a Performer RPM would've worked a little better but maybe the customer couldn't make it fit under the hood.
[Re: jwb123]
#2718822
11/24/19 11:56 AM
11/24/19 11:56 AM
Posts: 4,700 Wichita
GY3
Wichita
Mine is probably one of the slower of the bunch here naturally aspirated but there are a lot of concessions made to make it a true street car that is easy to drive.
505" with MCH CNC ported Stealths, 10.6:1 CR and very mild .545 234/240 @ .050 hydraulic roller cam. It has a ported Holley Street Dominator intake that lets everything fit under the stock, flat hood of my '63.Dodge. 850 Demon carb and small 1 3/4" Hedman headers.
With the 11" 2800 stall converter and 3.54 gear, it has run 11.1 @ 121mph. 60 ft. not so great 1.54-ish. 3,600 lbs.and mostly stock suspension up front. It drives like a normal 440 car from back in the day with a cam and headers.
Where it COMES ALIVE is with a small plate nitrous system. Nitrous LOVES that tight converter and 3.54 gear. Still sorting but has run a 6.48 and 105mph in the 1/8 mile on 200 shot. 1.37 60 ft. Has run 10.40 @ 130 in the 1/4 mile but recently figured some things out. This the exact same way I drive it on the street. 91 pump gas, through the mufflers and on the 275 Mickeys with 18 psi. I will occasionally pull 4-5 clicks out of the rear shocks to get it to ride better. LOL.
So much fun and very little maintenence required.
[Re: BradH]
#2718829
11/24/19 12:06 PM
11/24/19 12:06 PM
fast68plymouth
So. Burlington, Vt.
I can only think of one “bracket race” std port motor I’ve done. The rest I can remember were all milder street/strip combos.
This was a new shortblock and some updates to the owners heads. 493, 14:1, medium roller, gasket matched Victor, stage 2 rpms(300cfm). Made 615tq/665hp with a 1050 on an adapter. The owner had just bought a new AED HO750 that he was going to using on the motor....... I seem to recall it didn’t lose much power like that..... maybe 10-15hp.
Went in a 3600lb 65 Belvedere, Cal-Tracs, 10” tire...... best of 10.20’s with the 750 carb.
First or second time out it did a pretty big wheelstand, and at the point of maximum height, it broke the pinion gear in the 8-3/4 and came crashing down. New S60 after that.
[Re: Cab_Burge]
#2718875
11/24/19 02:39 PM
11/24/19 02:39 PM
fast68plymouth
So. Burlington, Vt.
Motor was fine....... tranny obviously had to come apart.
[Re: BradH]
#2718882
11/24/19 02:46 PM
11/24/19 02:46 PM
fast68plymouth
So. Burlington, Vt.
EDIT: I'm very happy with the my 3.75-stroke combination and it's a really good match for my car. I'm describing mine because it's a better example of what I was trying to ask than I think how most people understood my question. From what I’ve seen, when the heads are kinda “too small”....... adding cubes and lowering the CR really takes it’s toll on the upper rpm of the power curve. Even if the bigger motor makes considerably more tq, if it can’t carry it high enough....... you could end up not making much addition hp at all, and could also end up with a noticeably shorter usable power band. With that type of build, the overall car/motor/converter combo needs to really be able to exploit the added tq at the beginning of the power band.
