Re: What to change about my car for n/a
[Re: Clanton]
#2718332
11/22/19 10:49 AM
11/22/19 10:49 AM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Is one of those springs supposed to be a 943?
It’s def not the bottom one....... and unless the white paint used to be orange.......it’s not the top one either.
943’s shouldn’t be 280/680 either, unless the tester being used is just wrong.
What rocker ratio are you running and what’s the installed height?
[Re: fast68plymouth]
#2718334
11/22/19 10:54 AM
11/22/19 10:54 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Thanks I will have the springs tested.I may have mixed them up but the on head springs are the PSI like I posted. Is one of those springs supposed to be a 943?I have 1.5 rocker and 2" spring ht.
[Re: dvw]
#2718337
11/22/19 11:00 AM
11/22/19 11:00 AM
Clanton
northern,Ohio,USA
The trans is what has been holding me back starting at 10.30 at 131 ET and got worse going faster with 3 transmissions and 2 builders and I am tired of paying and adjusted to what worked.What else can I say. Your car should not hurt the trans. Dizusters turbo car runs a trans brake through a basically stock (good sprag, aluminum drum) 727. Been 9.55@142, 3750lbs. Runs on radials as well so it shocks it pretty good. No issues with the trans. Mine been 9.0@3350 without hard parts or clutch failure either. Doug
[Re: Clanton]
#2718341
11/22/19 11:09 AM
11/22/19 11:09 AM
fast68plymouth
So. Burlington, Vt.
Just to put it all in one place...... this is my suggestion:
Get CR to 9.0 or lower, reinstall blower, regrind cam to smaller street friendly lobes, set blower drive ratio for 5-6lbs boost.
#2718345
11/22/19 11:13 AM
11/22/19 11:13 AM
Clanton
northern,Ohio,USA
I agree And change valve springs to new cam.I agree but I just have to look at all options.TY Just to put it all in one place...... this is my suggestion:
[Re: Clanton]
#2718354
11/22/19 11:46 AM
11/22/19 11:46 AM
fast68plymouth
So. Burlington, Vt.
943’s set up at 1.920 would work fine with a suitable regrind of your current roller cam.
#2718358
11/22/19 12:00 PM
11/22/19 12:00 PM
Clanton
northern,Ohio,USA
Thanks.I have the shims I think to help adjust things. 943’s set up at 1.920 would work fine with a suitable regrind of your current roller cam.
[Re: Clanton]
#2718391
11/22/19 01:43 PM
11/22/19 01:43 PM
fast68plymouth
So. Burlington, Vt.
Why no more regrinds?
I had a couple done not that long ago.
If Comp won’t do it, I’m sure Bullet would.
It’s nice that they recommended a $450 set of springs to go along with those mild street lobes. FWIW, I think you can do better than the cam they recommended.
Like I said previously, the cam you have can’t be reground to something that small........ but it can definitely be reground into something that would work.
This looks like it could easily turn into a “too many cooks” scenario.
#2718396
11/22/19 01:58 PM
11/22/19 01:58 PM
Clanton
northern,Ohio,USA
The heat treat on my core was a problem and no longer use that core and I will give bullet a call.I will get my old springs tested too see what I have.I wanted a cam spec'd as a backup plan ps:My core # is RC239M if this sound any of you have 1.
[Re: Clanton]
#2718397
11/22/19 02:05 PM
11/22/19 02:05 PM
fast68plymouth
So. Burlington, Vt.
Okay...... so it’s not that they don’t regrind anymore, they just don’t want to regrind that cam. Has it been reground before?
Frankly, the cam is about the last thing you need. Get all the other stuff sorted out first....... then figure out what to do for a cam.
#2718399
11/22/19 02:09 PM
11/22/19 02:09 PM
Clanton
northern,Ohio,USA
Still no regrinds and stopped 6 months ago he[Dallas] said.My cam was new I have. Okay...... so it’s not that they don’t regrind anymore, they just don’t want to regrind that cam. Has it been reground before?
[Re: Clanton]
#2718400
11/22/19 02:10 PM
11/22/19 02:10 PM
fast68plymouth
So. Burlington, Vt.
Interesting.
I’d be very surprised if Bullet wouldn’t do it for you.
[Re: Clanton]
#2718433
11/22/19 05:49 PM
11/22/19 05:49 PM
fast68plymouth
So. Burlington, Vt.
Do you have 2” installed height with your parts?
