Re: Please help me ID my compression ratio and choose a piston.
[Re: viperblue72]
#2717618
11/19/19 05:48 PM
11/19/19 05:48 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I don’t believe they’re available any longer.
Besides, there are plenty of better options nowadays.
[Re: Twostick]
#2717661
11/19/19 08:15 PM
11/19/19 08:15 PM
Posts: 1,456 oklahoma
forphorty
oklahoma
So, assuming a stock cam, how is the horsepower and torque affected by running 9.6:1 instead of 10:1? 50HP? 10HP? If the old rule of thumb about 1 point of compression = 10% has any validity, I'd say 10ish. Kevin I would have to completely disagree with this. You are not going to get a 10% increase in power with a one point increase in compression. More like 3 to 4 percent maybe, with the gains being greatest on really low compression engines. The difference between 9.6 and 10.0 on a stock 440? Wild azz guess,5 hp. Maybe. Or less. You will never know the difference.
[Re: forphorty]
#2717674
11/19/19 08:54 PM
11/19/19 08:54 PM
fast68plymouth
So. Burlington, Vt.
You could see just about a 3% increase in power going from 9:1 up to 10:1.
So, on a 350hp motor....... about 10hp.
[Re: fast68plymouth]
#2717777
11/20/19 09:25 AM
11/20/19 09:25 AM
Posts: 2,158 God's Country - Etowah, TN.
A34
The question has been answered.
One of the 3 flat top pistons I listed, deck block/mill heads/gasket thickness to arrive at 10:1...... done.
If you don’t want to mill anything....... you’ll need to have custom pistons made. Yes, thank you! I am looking at those now. I appreciate everyone trying to help and was answering clarifying questions by others. Whichever I choose, I will get the block decked to make up any difference.
God Bless America, Our Troops and Their Families !
DEO VINDICE
