Re: How many miles per oil change on your Cummin trucks?
[Re: RTSrunner]
#2729990
01/04/20 02:11 PM
01/04/20 02:11 PM
Posts: 125 kalispell montana
jwilson 61
kalispell montana
A noise filter on your Apps wire works wonders on those also , Available thru BD diesel or ebay, Dodge cummins diesel noise filter,
70 cuda 440 6bbl Auto with a dana 60 68 road runner QQ1 383 auto 1970 6 barrel 4 speed Superbird FY1 number matching 15 Challenger 6.4 SRT pearl White 6 Speed 72 Cuda 440 5 speed 71 Road Runner 440 4 speed
[Re: jwilson 61]
#2730085
01/04/20 07:04 PM
01/04/20 07:04 PM
Posts: 20,698 in a cattle trailer down by th...
Guitar Jones
I change mine at 6K but it is an old VE pumped 12 valve. It is my daily driver though getting at let 80 miles a day.
[Re: Guitar Jones]
#2730137
01/04/20 11:17 PM
01/04/20 11:17 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
I was told by the dealer fleet sales rep to change it at 7500 miles, I haven't done that ever. I was trying to change the oil and filter around 3500 miles. I've heard the oil will quit getting dirty right away after changing once the motor gets broken, between 35,000 to 60,000 miles, mine hasn't done that yet at 151,000+ miles I'm going to try changing it around 5,000 miles now for a while and see if I like that or not Thanks for the help to all of you
[Re: RTSrunner]
#2730162
01/05/20 01:29 AM
01/05/20 01:29 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
I have an ‘02 2500 Cummins 4x4. I change every 10,000 miles I use Valvoline Premium Blue and Fleetguard Stratapore filters. Bought the truck a couple years ago at 130k, I’m at 250k now.
If I can just get the damned thing to STOP going in and out of lockup it’d be a good truck. I might switch to an NV5600 6 speed. Other than that, no performance mods. No chip, no tuner no injectors, stock transmission. I’d really like to turn up the heat on it, what am I missing? More go power would be nice. You need to relocate and sheild that large blk/tan ground wire that runs over the top of your alternator. Made a lot of $$ doing that back in the day. More info on this please:) and thanks Passenger side near the battery..... large blk/tan wire. You’ll see it goes to two gray connectors mounted on the batt tray. I eliminate those connectors by removing the terminals and solder them. Next I remove the wire from the harness past the alternator and cover the blk/tan with foil tape and some black convoluting cover. I then route the wire over the black metal top alternator mount. I’d post picts if photobucket didn’t go to L! If you want picts pm me your phone # and I’ll text them.
[Re: J_BODY]
#2730451
01/06/20 03:35 AM
01/06/20 03:35 AM
Posts: 1,882 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
If I can just get the damned thing to STOP going in and out of lockup it’d be a good truck. I might switch to an NV5600 6 speed. Other than that, no performance mods. No chip, no tuner no injectors, stock transmission. I’d really like to turn up the heat on it, what am I missing? More go power would be nice. You need to relocate and sheild that large blk/tan ground wire that runs over the top of your alternator. Made a lot of $$ doing that back in the day. More info on this please:) and thanks Passenger side near the battery..... large blk/tan wire. You’ll see it goes to two gray connectors mounted on the batt tray. I eliminate those connectors by removing the terminals and solder them. Next I remove the wire from the harness past the alternator and cover the blk/tan with foil tape and some black convoluting cover. I then route the wire over the black metal top alternator mount. I’d post picts if photobucket didn’t go to L! If you want picts pm me your phone # and I’ll text them. PM sent,Thanks J-Body for the reply,RT
[Re: RTSrunner]
#2740723
02/07/20 05:10 PM
02/07/20 05:10 PM
Posts: 851 Avondale AZ
Prodart440
Avondale AZ
I go between 10,000 and 12,000 miles on mine. I have used Amsoil since around 80,000. I send a sample in to be tested every time. 254,000 miles and going strong.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: Prodart440]
#2740745
02/07/20 06:20 PM
02/07/20 06:20 PM
Posts: 16,167 Mesa, Arizona
dart4forte
Mesa, Arizona
Bought my 07 2500 from Dave Smith over 13 years ago. I’m now pushing 300k. Most of which was up in Yakima. Now in Phoenix. Started running Amsoil 15/40 starting at 15k. Doesn’t use a drop of oil. I change at every 7500 miles. Using WIX filters.
Abe Lincoln
[Re: Cab_Burge]
#2741103
02/08/20 11:27 PM
02/08/20 11:27 PM
Posts: 6,571 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I was told by the dealer fleet sales rep to change it at 7500 miles, I haven't done that ever. I was trying to change the oil and filter around 3500 miles. I've heard the oil will quit getting dirty right away after changing once the motor gets broken, between 35,000 to 60,000 miles, mine hasn't done that yet at 151,000+ miles I'm going to try changing it around 5,000 miles now for a while and see if I like that or not Thanks for the help to all of you Nature of the beast Cab. Some are worse than others. My Cat stays fairly clean looking right up to 12,000 miles. My N14 Cummins was black by the end of the driveway. I think ring design and better filtering on the Cat account for most of the difference. Cummins filter specs are considerably more lax than Cat. A Cummins N14 fuel filter is 10 micron. A Cat is 3. Kevin
