Re: P4529724 intale B block any good
[Re: mopar dave]
#2716368
11/16/19 12:37 PM
11/16/19 12:37 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
From one of Andy’s tests, on your favorite BB combo: With that done, we grabbed the wrenches and replaced the Trick Flow intake with a Mopar M1 4500 intake. Most people are familiar with the M1 4150 intakes, but Mopar also sells a line of M1 intakes with large plenums and a Dominator bolt pattern. The M1 4500 is an excellent race intake on the smaller 383- to 400-inch engines, but it struggled to feed our 470-inch engine. Peak torque picked up a bit, but peak power was only 687 hp at 6,300 rpm. I believe prior to that they had seen 700hp using the TF intake and a 4150 carb.
[Re: fast68plymouth]
#2716379
11/16/19 01:05 PM
11/16/19 01:05 PM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
ok, couldn't remember. That is the only other intake I see available with the Dominator flange for B block. The TF would be my #1 pick, but it wont fit under my hood with adaptor and Andy said it lost 18hp with the 4150/4500 adaptor on it. guess i could put my 950 on it, but seems like that would be going backwards. A Wilson ported M1 with standard ports worked better with my 270 heads than an OOTB Indy 400-2 intake. Once the 400-2 was ported then it worked better. The Indy 400-2 out of the box was a pig. Once it was reworked by Wilson it ran pretty well. Your results may vary. I was working with a fairly well sorted out combo. That was a pump gas 470 that was making over 750 hp. I think the best set of pulls was 780 hp. Most guys don't spend the time and money to dial in a combination like that. If you knock 100 hp off the engine then the OOTB intake probably works just fine.
[Re: mopar dave]
#2716388
11/16/19 01:24 PM
11/16/19 01:24 PM
fast68plymouth
So. Burlington, Vt.
I didn’t think they’d been available for a few years, but there might be a few kicking around somewhere.
Just keep in mind the one Andy used to get good results with was the $1600 variety.
And then...... the $1600 job on the 400-3 was better than the $1600 M1........ so I’m not sure how this is a step toward.
But....... the interesting test would be to try the M1 without the $1600 job, and see how it compares with what you have. (It’s not what I would do...... but I’d still think the results were interesting)
[Re: AndyF]
#2716405
11/16/19 02:22 PM
11/16/19 02:22 PM
fast68plymouth
So. Burlington, Vt.
Andy, didn’t you have a pic of the stock one and the modified one next to each other?
#2716417
11/16/19 02:52 PM
11/16/19 02:52 PM
BradH
I didn’t think they’d been available for a few years, but there might be a few kicking around somewhere. The vendor who I thought still had the B-block version in stock shows 0 units now. They do show 2 of the RB version on hand, presuming they keep their web site up to date. Don't know how the RB version w/ Andy's 4150/4500 shear plate adapter (I think I bought his last one) would compare to my RB Trick Flow 4150. I have experience only w/ modified RB 4150 M1 intakes, which make good torque but don't make the peak HP of something like a Victor 4150 or Trick Flow 4150. The big advantage of the M1s are their low height compared to the Victor/Trick Flow style intake. Figure as much as an inch lower at the carb mounting pad, IIRC, although the M1s are angled w/ the carb lower at the front of the intake. EDIT: I looked closely at the "before" and "after" pics of Andy's B-block intake that got Wilson-ized. The more I looked, the more I saw where they'd welded material to allow the runners to be opened up from the plenum to about half way down to the head. A sh!tload of work went into that thing...
[Re: BradH]
#2716424
11/16/19 03:15 PM
11/16/19 03:15 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
The big advantage of the M1s are their low height compared to the Victor/Trick Flow style intake. Figure about an inch lower at the carb mounting pad, IIRC I had a large plenum M1 4500 with a dominator on my 493 and I couldn't close the hood with an air cleaner on it, With a Victor and a 4150 I can use a 3" drop base air filter so I believe the Victor might be lower Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
#2716426
11/16/19 03:19 PM
11/16/19 03:19 PM
Posts: 31,044 Oregon
AndyF
Andy, didn’t you have a pic of the stock one and the modified one next to each other? I think so but I'll have to wait until later. Heading to the state championship game at the moment to watch my daughter play.
#2716439
11/16/19 03:34 PM
11/16/19 03:34 PM
fast68plymouth
So. Burlington, Vt.
A little more of an issue on the other side with this particular manifold.....
[Re: mopar dave]
#2716441
11/16/19 03:36 PM
11/16/19 03:36 PM
fast68plymouth
So. Burlington, Vt.
I’ve never tested a std port intake on MW heads.
[Re: mopar dave]
#2716455
11/16/19 04:12 PM
11/16/19 04:12 PM
fast68plymouth
So. Burlington, Vt.
Even if it’s not something I’d do myself....... I still to like see what other people try, and how it works out for them.
If a particular engine build plan calls for MW heads, then I’m going to use a MW manifold with them.
If I thought the engine could get by with the std port csa....... I’d use the smaller heads along with the smaller manifold.
About the only time I would do the small intake/big head thing is if I were using a head with the std opening/MW sized port..... like an SR or EZ....... where the port opening is std port size, but once you get into the port 1/2” or so, it opens up to MW size. I would normally use this configuration with “smaller” ci builds, or milder stroker builds for heavier vehicles where the race type MW single plane intake isn’t a good match for how the car will be used.
Nowadays, it’s basically the same sort of decision for someone deciding on whether or not to use TF 240’s or 270’s.
