Re: Bigger rocker on the intake?
[Re: AndyF]
#2715917
11/14/19 09:01 PM
11/14/19 09:01 PM
Posts: 4,457 Washington
madscientist
Washington
It just depends. I've had engines that pick up with more rocker ratio and engines that don't. Generally speaking the smaller the cam the more likely you'll see a gain from the rockers. If the cam is already opening the valves as fast as the engine needs then opening them faster costs power, it doesn't add power. Andy, do you think the lobe is just too fast, or maybe that fast lobe is being opened too early? I ask because if the lobe is faster, the seat timing is less, but the @.050 timing will be quicker than the slower lobe. And it will be quicker to .200 and so on. Seems to me that more aggressive lobe should be opened later. Does this make sense?
[Re: AndyF]
#2716068
11/15/19 11:24 AM
11/15/19 11:24 AM
Posts: 4,212 New York
polyspheric
New York
The best candidate for a higher intake rocker ratio is: 1. under-cammed 2. does not need exhaust duration bias (longer exhaust period) 3. wedge chamber with shallow stem angle and valve head close to the bore 4. has enough head capacity and lower end strength to operate at higher RPM 5. not coil bound at new lift (or new springs)
Your porter's input is very valuable here as to relative port capacity in/ex.
Boffin Emeritus
[Re: AndyF]
#2716071
11/15/19 11:39 AM
11/15/19 11:39 AM
fast68plymouth
So. Burlington, Vt.
“It depends”
And.....
There’s only one way to know for sure how a particular combo will respond to an increase in ratio.
[Re: viperblue72]
#2716575
11/16/19 11:03 PM
11/16/19 11:03 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Update: This motor has a dual pattern cam: .619/.631 - 270*/276*
And that is paired with a rocker combo of 1.7 intake and 1.6 exhaust. Thereby reversing the dual pattern cam lift. Results are .700” intake and .673” lift.
Can someone explain that logic? I’m not the sharpest tool in the shed, but doesn’t that work against heads that are 66% intake to exhaust air flow??
Thank you in advance for any info!
[Re: cudadoug]
#2716613
11/17/19 06:18 AM
11/17/19 06:18 AM
Posts: 10,018 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The intake valve is larger requiring more lift to see maximum flow. The exhaust is opening with what, 100 psi pressure? Plus it has the big advantage of exhaust scavenging. So intake and exhaust are two totally different animals. When a blower is added to the mix, now you have much more force to fill the cylinders. And a lot more exhaust volume to expell. That is why forced induction engines will perform better with a somewhat larger exhaust valve and a bit smaller intake.
[Re: viperblue72]
#2716645
11/17/19 11:05 AM
11/17/19 11:05 AM
polyspheric
New York
You’re gonna gain more by the extra duration on the exhaust than a bit of lift
This^^^
Boffin Emeritus
[Re: gregsdart]
#2717408
11/19/19 04:39 AM
11/19/19 04:39 AM
Posts: 14 Sydney Australia
sr440
Sydney Australia
The intake valve is larger requiring more lift to see maximum flow. The exhaust is opening with what, 100 psi pressure? Plus it has the big advantage of exhaust scavenging. So intake and exhaust are two totally different animals. When a blower is added to the mix, now you have much more force to fill the cylinders. And a lot more exhaust volume to expell. That is why forced induction engines will perform better with a somewhat larger exhaust valve and a bit smaller intake. Exactly! I am always amazed when a motor makes good power with a cam with a single pattern. What are the chances of the intake & exhaust needing the same pattern????
[Re: sr440]
#2717423
11/19/19 07:57 AM
11/19/19 07:57 AM
gregsdart
Exactly! I am always amazed when a motor makes good power with a cam with a single pattern. What are the chances of the intake & exhaust needing the same pattern???? [/quote] Compression ratio has a big effect. A low compression engine ,say 8/1, still has usable cylinder pressure farther down the bore than a. 16/1 motor so the 16/1 motor can get away with a lot more exhuast duration. The decrease in working pressure of the 16/1 motor occurs twice as fast since the volume in the cylinder doubles twice as fast.
