Re: How long do windshields typically last?
[Re: Sniper]
#2714680
11/10/19 11:38 PM
11/10/19 11:38 PM
Posts: 10,631 Freeport IL USA
poorboy
Freeport IL USA
Old windshields tend to get scratches, surface imperfections, chips, and cracks before they de-laminate. They get hard to look through in bright sunlight or at night with car headlights approaching, you long before they separate. If the glass is clear, it should last a long time. I run a lot of 30s, 40s & 50s stuff, If new glass is available and isn't really expensive, I wouldn't even consider putting in used glass, especially a used windshield. Gene
[Re: poorboy]
#2714689
11/11/19 12:36 AM
11/11/19 12:36 AM
Posts: 9,554 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
I would think a replacement might be, or id hope might be better tech and break a bit different for the good when the air bags in ones hellcat 70 cuda dont deploy.
STOP POTATO HATE!
[Re: QuickDodge]
#2716016
11/15/19 09:14 AM
11/15/19 09:14 AM
Posts: 7,545 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Age doesn't matter - if it's still in good condition now.
Salvage yard glass can be awesome, just bring a squeegee, water/windex and papertowels, something to clean them to check first. Delaminating you can see almost immediately, so that's easy. Then check for pitting and scratches after a thorough cleaning.
There was a time when we had no kids, I spent lots of time in salvage yards. The glass I found here that were the best, were in old tree-covered yards, where the car was sitting for decades. - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: poorboy]
#2716028
11/15/19 09:43 AM
11/15/19 09:43 AM
Posts: 22,709 Bitopia
jcc
Bitopia
Old windshields tend to get scratches, surface imperfections, chips, and cracks before they de-laminate. They get hard to look through in bright sunlight or at night with car headlights approaching, you long before they separate. If the glass is clear, it should last a long time. I run a lot of 30s, 40s & 50s stuff, If new glass is available and isn't really expensive, I wouldn't even consider putting in used glass, especially a used windshield. Gene I agree, I got 490K on my PU, and currently in the process of deciding whether its worth installing the third new windshield from all the tiny chips, that mainly effect night driving. My semi windshield though has fogged up around the edges maybe three times over the years, with under 20K miles, and has to be replaced because of DOT regulations every time I haven't seen a lot of delamiination issues enough to be concerned..
[Re: QuickDodge]
#2716070
11/15/19 11:38 AM
11/15/19 11:38 AM
Posts: 8,403 Highland, MI.
Sunroofcuda
Highland, MI.
I fully agree with some of the above positive comments.
I worked for a couple of auto glass distributors back in 1978-79 & windshields (which are laminated) we built even better back then as far as I'm concerned - they were a bit thicker glass than today's windshields. If you find a good used windshield & it is not de-laminating, then it will not start. The plastic they use to laminate the two sheets of glass together is tough as nails & stays clear. Just don't chip any of the edges of the glass - removing a windshield from a vehicle has to be done very carefully - do it slow & careful.
On an interesting note, the first distributor I worked for had all kinds of brands of glass - PPG, Carlite, LOF, Mopar, etc. We had a Mopar clear Superbird back glass in stock - in the cardboard wrapper. I could have probably bought it for $70.00 & really wanted to, but $70.00 was way more than I could afford back then. Those were the days.
[Re: Sunroofcuda]
#2716128
11/15/19 03:36 PM
11/15/19 03:36 PM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
My 03 dually has 282K on it and is definitely in need of a new one... Never a mark big enough to cause a crack but 1,000 little marks everywhere is making it a lot harder to see when driving into the sun... I've never had an issue reusing old glass as long as it is good shape...
...FAFO...
