Re: What octane fuel for factory stock 318? [Re: David1971] #2893267
02/26/21 01:15 AM
02/26/21 01:15 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Incredible gas station! Send one my way. Wow
I want my fair share
Re: What octane fuel for factory stock 318? [Re: David1971] #2893351
02/26/21 12:35 PM
02/26/21 12:35 PM
GMP440 Online content
GMP440  Online Content
If you are using the Chevron 98, then you can bump timing to 8 degrees tdc. You can even go up to 10 degrees btdc and still have no pinging.
Re: What octane fuel for factory stock 318? [Re: Twostick] #2893464
02/26/21 05:30 PM
02/26/21 05:30 PM
Originally Posted by Twostick
If it's a non Magnum, I'm surprised it doesn't rattle with 8 deg initial. I had a 69 Belvedere with a 318 many years ago and factory timing spec was TDC. If you tried to add any timing at all on regular gas, it rattled and that was before unleaded fuel.
Kevin
Same with my 68 Coronet with 318. Factory timing for my 68 was 2 1/2 degrees ATDC, that is stated on the green tuning spec sticker on the fender. It actually runs good and no pinging with that timing.
However, I keep it set at TDC, but if I set it to 5 degrees or 10 degrees BTDC, the 318 pings and have to use 100 octane avgas to stop it from pinging. So I just stay at TDC on 87 octane.
Re: What octane fuel for factory stock 318? [Re: GMP440] #2893682
02/27/21 12:24 PM
02/27/21 12:24 PM
moparx Offline
moparx  Offline
at what rpm does the pinging occur ? in all gears ?
beer
