Re: 1956 Pickup
[Re: Twostick]
#2718527
11/23/19 01:05 AM
11/23/19 01:05 AM
Posts: 6,561 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
ECI is another brake kit vendor. They used to go to Carlisle but I haven't seen them there in years. Ralph is the guy's name IIRC. I spoke to him there one year and and was impressed with his engineering of the kits and the reasons he chose the components he uses. He lists a kit for a 52 Dodge pickup, whether the spindles are the same as yours or not, I don't know but he could tell you if they would work or not. He used to offer a kit IIRC for A100 and I think D100 Sweptlines too but I don't see them in the catalog. He sells a pretty spiffy looking tube bender too. http://www.ecihotrodbrakes.com/index.htmlKevin
Re: 1956 Pickup
[Re: Twostick]
#2719028
11/24/19 10:28 PM
11/24/19 10:28 PM
Posts: 10,550 Freeport IL USA
poorboy
Freeport IL USA
Actually, the bottom anchors are also cam offset and will move the bottom of the shoes in or out as well. These brakes are a pita to get properly set, they work great once set, but if they are incorrect, the brakes pretty well suck.
I have a 54 Dodge truck service manual here. The bolts on the bottom are called the anchor bolts, both are suppose to have either an arrow or a punch mark that identifies the inside position of the anchor bolt. The adjusting cams under the shoes are referred to as the cam. the text also refers to the "toe of the shoe" and the "heal of the shoe". The bottom of the brake lining on each shoe on both sides are referred to as the "heal" and the top of the lining on both shoes are referred to as the "toe". Each shoe has a toe at the top, and a heal at the bottom. From the 54 Service manual: Major brake adjustment Be sure the master cylinder is full (paraphrase)
Position the anchor bolts and remove the tire assembly. Remove the inspection cover. Loosen lock nuts and turn brake shoe anchor bolts to fully released position, with the flats of the anchor bolts horizontal and the punch marks on the threaded ends of any pair of anchor bolts together and in line.
(1) Adjust the anchor bolt and cam on one of the shoes to give equal clearance at the toe and the heal. Make sure that sufficent center contact is maintained to produce a slight drag.
(2) After adjusting the clearance on one shoe, repeat the procedure on the other shoe.
(3) After the toe and heal clearance on both shoes have been equalized, install the tire and wheel assembly. Then, using the top adjusting cam, bring the shoe out until a moderate drag is obtained.
(4) Perform this procedure at all four wheels.
The book also goes into detail to be sure the brake shoes are aligned (square with the drum).
It also discusses brake pedal travel. There are 2 long paragraphs about free travel, and travel of the piston required to cover the relief port. Then it covers the travel of the brake shoes to contact the drums, I'll post that last paragraph:
An additional pedal travel of approximately 1 inch is required to move the shoes outward against the drums. The total pedal travel required to set the shoes should be approximately 1 3/4 inches to 2 inches with properly adjusted brakes. A minor brake adjustment (#3 & #4 above) will usually correct excessive pedal travel.
Good luck adjusting your drum brakes. Gene
That procedure should be incentive enough to put disc brakes on it. Kevin Also given the fact these are not self adjusting as the shoe wares off, and you get to adjust the brakes with every oil change should add a bit more incentive to step up to disc brakes, but some people like to keep things all original. Gene
