Now you guys have me wondering if i should run a higher compression ratio? At 528 cubes i believe i was at 15.1 to 1. If i reuse the pistons as is with the same deck hieght I would be about 16 to 1. I would need to upgrade to cometic gaskets so not cutting the domes would make it about a wash. Thoughts? Mega block by the way. 440-1 professionaly ported heads with 400 cfm at .800 intake lift. Net intake lift about .840 to 8.50 (gross .870) Alky injected
Edit; i just s t arted a new thread on this.
