Re: Help!!Time to drill throttle blades?
[Re: RTSE4ME]
#2711031
10/29/19 09:31 PM
10/29/19 09:31 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
you have a fully adjustable carburetor and should not have to revisit the 1980's to tune it. this should be a simple idle air bleed change where are the idle mixture screws set? should be between 1-2 turns out.
joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#2711038
10/29/19 09:58 PM
10/29/19 09:58 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’ve had a lot of carburetors on my cars over my lifetime and have never had to drill holes in my plates. Never had to never will
[Re: RTSE4ME]
#2711043
10/29/19 10:17 PM
10/29/19 10:17 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#2711063
10/29/19 11:25 PM
10/29/19 11:25 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
If it has something like .068-.073 idle air bleeds drill them out to .075 and see if that helps. I have never had to drill the plates on a carb if the IAB was correct. The timing should be 12-20 initial and 32-38 total. More initial with bigger cam/more overlap. Open chamber OEM style heads seem to like more towards 38 total where the more efficient engines I have worked on like 32-34 total.
[Re: Cab_Burge]
#2711070
10/29/19 11:53 PM
10/29/19 11:53 PM
Posts: 2,059 MD
RTSE4ME
MD
BTW, what do you mean with the "latest timing curve"? What does it idle at and where, what, RPM, and how much total timing does it have a what RPM also? I have no clue on the new gen 3 hemi ignition parts or how they are set up Good luck, let us know your results I was programming different curves into the MSD ignition controller to see if it would help. The current ignition curve 0-900 rpm ramps to 28 degrees. 900-3100rpm is 28 degrees 3100-5000 rpm ramps down to 24. The best idle I have so far is 1350rpm in neutral and 1000 in gear but it was running on the primary transfer slot. Engine will not idle with both transfer slots closed.
[Re: Jeremiah]
#2711073
10/30/19 12:04 AM
10/30/19 12:04 AM
Posts: 2,059 MD
RTSE4ME
MD
If it has something like .068-.073 idle air bleeds drill them out to .075 and see if that helps. I have never had to drill the plates on a carb if the IAB was correct. The timing should be 12-20 initial and 32-38 total. More initial with bigger cam/more overlap. Open chamber OEM style heads seem to like more towards 38 total where the more efficient engines I have worked on like 32-34 total. IABs are currently .070. I will drill them or pick up some 75s. Currently I ramp up to 28deg by 900rpm. G3 Hemi's are supposedly very efficient and don't need a lot of timing.
[Re: RTSE4ME]
#2711081
10/30/19 01:22 AM
10/30/19 01:22 AM
Cab_Burge
You might want to try between 14 up to 20 degrees at idle up to 2000 RPM and up to 30 degrees above 2000 RPM That carb should idle on the idle circuit only unless one of the idle fuel feed circuits is plug up or maybe it is defective When you open up the air bleeds, all three circuits or two circuit carbs., you are leaning that circuit out, if you make the air bleed holes smaller you will richen it up
[Re: pittsburghracer]
#2711105
10/30/19 07:37 AM
10/30/19 07:37 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I’ve had a lot of carburetors on my cars over my lifetime and have never had to drill holes in my plates. Never had to never will Actually some Holley carbs come right out of the box with the primary plates drilled with a .125 hole in each one. Ron
[Re: 383man]
#2711113
10/30/19 07:54 AM
10/30/19 07:54 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’ve had a lot of carburetors on my cars over my lifetime and have never had to drill holes in my plates. Never had to never will Actually some Holley carbs come right out of the box with the primary plates drilled with a .125 hole in each one. Ron Yes but technology has changed and carbs are more tunable now. And like you said some carbs came that way. No longer needed.
#2711130
10/30/19 09:12 AM
10/30/19 09:12 AM
BradH
I’ve had a lot of carburetors on my cars over my lifetime and have never had to drill holes in my plates. Never had to never will Actually some Holley carbs come right out of the box with the primary plates drilled with a .125 hole in each one. Ron Yes but technology has changed and carbs are more tunable now. And like you said some carbs came that way. No longer needed. I still think it depends upon the carb and the application. Every Braswell 4760/4825 or Braswell-modified Holley 4150 I've seen over the years (and that includes what they're selling new today) has drilled throttle plates. If you can't get the ide speed up where it needs to be unless you're off the idle circuit and the carb doesn't have an internal bypass air bleed adjustment that can be tuned, what other choices are there? FWIW, I'd like to hear from the OP on how the carb ran out-of-the-box, since the settings he posted above aren't. Also, I a$$ume he's tracking AFR, too, and wonder what he's seeing.
[Re: RTSE4ME]
#2711143
10/30/19 09:52 AM
10/30/19 09:52 AM
Posts: 2,094 central texas
krautrock
central texas
you don't really have to adjust the prim and sec blades so that the transfer is exposed the same amount for each. the baseplate might have a shorter transfer slot on the secondary side. One way to do it adjust them evenly and expect the secondary side to be hidden or just on the verge of peeking past the blade. I usually adjust the front to roughly .020 exposed on the transfer slot and then adjust the rear to show about the same area of light showing as the primary side if i hold the carb up to some light and look up through the venturis from the baseplate side... a good starting point at least. from there roughly adjsut the prim and sec sides evenly to get your idle speed.
[Re: BradH]
#2711172
10/30/19 10:48 AM
10/30/19 10:48 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I’ve had a lot of carburetors on my cars over my lifetime and have never had to drill holes in my plates. Never had to never will Actually some Holley carbs come right out of the box with the primary plates drilled with a .125 hole in each one. Ron Yes but technology has changed and carbs are more tunable now. And like you said some carbs came that way. No longer needed. I still think it depends upon the carb and the application. Every Braswell 4760/4825 or Braswell-modified Holley 4150 I've seen over the years (and that includes what they're selling new today) has drilled throttle plates. If you can't get the ide speed up where it needs to be unless you're off the idle circuit and the carb doesn't have an internal bypass air bleed adjustment that can be tuned, what other choices are there? Exactly... Technology has changed but my old Holley DP (2-corner idle) and mushroom cam hasn't With the transfer slots "square" on primary and secondary, and PCV operating, the only way to get enough additional air into my 451 with 272@.050 cam was to drill all four blades. Don't remember the size right now but think 3/32". Now it idles at 1000-1050 at 7"Hg. Someday I'll spring for a 4-corner carb and have Thumperdart go through it
[Re: DrCharles]
#2711219
10/30/19 12:32 PM
10/30/19 12:32 PM
Cab_Burge
He can convert yours, if he still does that I shoot for 14.3 to 15.5 AFR at idle by restricting the idle fuel feeds on 4 corner carbs, that usually results in less than 300 RPM drop from idle to neutral warmed up. My old pump gas 518 C.I. six pack motor with a solid roller cam with 260 @.050 on the intakes with a 108 LSA installed at 106 ILC would idle at 850 RPM in gear and at 1000 RPM in neutral with 14 degrees timing It wasn't easy to get the carbs, all three of them, to do that but it was well worth figuring out how to do that
[Re: RTSE4ME]
#2711227
10/30/19 12:57 PM
10/30/19 12:57 PM
BradH
OP - How far would you have to drive (or tow?) to Sterling VA from where you are in MD to see if this one runs better / worse / no differently? Oh, look... holes in the throttle plates. This isn't even a sales pitch, although I do have it listed. If mine runs better than yours, then my tune & setup could help you figure out what direction to go w/ yours. Besides, I think I still owe you a favor for the Hurst line-lock switch you sent me. - Brad
[Re: Cab_Burge]
#2711228
10/30/19 12:58 PM
10/30/19 12:58 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Braswell still uses drilled butterflies, as do other builders. In some cases, not saying this one it is a useful tool. Not all things old school are totally obsolete
#2711243
10/30/19 01:31 PM
10/30/19 01:31 PM
Posts: 4,457 Washington
madscientist
Washington
I’ve had a lot of carburetors on my cars over my lifetime and have never had to drill holes in my plates. Never had to never will Actually some Holley carbs come right out of the box with the primary plates drilled with a .125 hole in each one. Ron Yes but technology has changed and carbs are more tunable now. And like you said some carbs came that way. No longer needed. Now they make carbs with built in adjustable idle bleeds. Many carbs need it. To say it's old school and doesn't work or isn't needed is just bullheaded.
