Re: would you call this normal Stage V heads and manifold [Re: ] #2805396
08/05/20 12:54 PM
08/05/20 12:54 PM
Waiting has paid off up it looks like to me bow grin
Re: would you call this normal Stage V heads and manifold [Re: Cab_Burge] #2805500
08/05/20 05:45 PM
08/05/20 05:45 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Is that an allusion that the first intake valve looks bigger than the rest.
Re: would you call this normal Stage V heads and manifold [Re: OUTLAWSSAA] #2805503
08/05/20 05:54 PM
08/05/20 05:54 PM
Kirkland, Washington
Pacnorthcuda Offline
No, it’s just an illusion.
Re: would you call this normal Stage V heads and manifold [Re: ] #2805642
08/06/20 07:30 AM
08/06/20 07:30 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
The gap between the block and the intake will decrease when you install the head gaskets under the heads. That will spread the heads apart further and allow the intake to drop down. Although a wide gap is fairly common that I have seen on many hemis, that gasket is quite thick. I have in the past machined 3/16 spacers to tighten the gap.
