would you call this normal Stage V heads and manifold
#2710062
10/25/19 09:20 PM
10/25/19 09:20 PM
Superfreak
Superfreak
Re: would you call this normal Stage V heads and manifold
[Re: 469runner]
#2710078
10/26/19 12:11 AM
10/26/19 12:11 AM
Superfreak
Superfreak
Block was machined by FHO The last set of Stage V heads I got from FHO were nothing like these.
[Re: ]
#2710079
10/26/19 12:19 AM
10/26/19 12:19 AM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
No way would I accept the castings, as said Porosity, it might OR might not spring leaks over time.
[Re: fastmark]
#2710096
10/26/19 08:07 AM
10/26/19 08:07 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
I got a set of millennium heads like that once from modern that I sent back. They may be fine, or they may leak after running a while who knows. I do know this, I had a set of predator heads from before indy selling them that had that same amount of porosity. We ported them a fair amount. They sprang leaks in the intake 3 different times. Chasing them with the tig torch was aggravating, and I finally just ran stop leak. They're still being used by a buddy, so not really a problem. He runs stop leak and they're not leaking, but unless I was offered a discount for them being that way, I'd opt out. Different if it was a 1 off, be glad you have them type deal.
As far as the china wall gap, as long as ports and bolt holes line up I wouldn't care about that at all. Cut a strip of aluminum to fill it, or fill it with ultra grey.
[Re: dthemi]
#2710107
10/26/19 09:47 AM
10/26/19 09:47 AM
Superfreak
Superfreak
I just looked back at pics Tim sent me of my heads when they were completed and there is no pitting on those heads. These heads will be going back.
[Re: ]
#2710125
10/26/19 10:56 AM
10/26/19 10:56 AM
Posts: 19,568 north of coder
moparx
as a machinist with 42+ years machining aluminum, those heads are junk. there is WAY too much porosity, the sealing surface is terrible, and those little "boogers" [for lack of a better word] on the surface indicate that casting is gummy/soft. my opinion, send it back. i would NOT accept it under any circumstances.
[Re: ]
#2710165
10/26/19 02:11 PM
10/26/19 02:11 PM
Posts: 1,051 The Great White North
RAMM
I'm surprised nobody mentioned the crack in the bolt hole in the first image. I can see a crack in another image as well. Those heads are made from beercans or something. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: The Shadow]
#2710224
10/26/19 06:49 PM
10/26/19 06:49 PM
Superfreak
Superfreak
Just call him if you're not happy. I'm sure the intakes come oversized so you can adjust for head gasket thickness The heads are o-ringed so no gasket. Tim has replied to my email and has told me to send the heads back. He also stated that the gap is for a gasket, which is obvious but I thought 1/4" was pretty excessive. I am in no way Bashing what so ever, just asking opinions of the product I received.
[Re: ]
#2710264
10/26/19 09:45 PM
10/26/19 09:45 PM
Posts: 2,117 Byron, NY
W.I.N. Racing
Byron, NY
That end gap is typical (especially on Blown stuff) a 1/4" foam gasket is used. I also use a retainer. There are two types a "U" channel style and bolt on wall type. I prefer the Channel style.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: krautrock]
#2710325
10/27/19 09:45 AM
10/27/19 09:45 AM
Posts: 2,675 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
This is all very strange to me. Normally Stage V castings are so beautiful it's ridiculous. I don't know who casts his stuff but they are good. And to look so accurate I assume those are Chryslers old patterns.
2011 Drag Pak Challenger
[Re: Cab_Burge]
#2710386
10/27/19 01:59 PM
10/27/19 01:59 PM
rickseeman
Stuttgart, Arkansas
He said it has O-ring ports so the fit will be more like it is seen. The head gaskets will lessen the gap some on the china wall.
[Re: rickseeman]
#2805177
08/04/20 08:18 PM
08/04/20 08:18 PM
Superfreak
Superfreak
[Re: ]
#2805337
08/05/20 10:16 AM
08/05/20 10:16 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Looks like a bad casting. Those need to go back. lol new ones look great
[Re: ]
#2805338
08/05/20 10:16 AM
08/05/20 10:16 AM
rickseeman
Stuttgart, Arkansas
Yeah, that's what I'm talking about.
