Big Block A-body front weights? #2705484
10/10/19 11:08 AM
10/10/19 11:08 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
For those of you that have weighed your big block A-bodies, what were the front end weights of them?
Also, is there a rule of thumb for estimating the front unsprung weight for a stock disc brake set up?
Re: Big Block A-body front weights? [Re: mopowers] #2705513
10/10/19 12:40 PM
10/10/19 12:40 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
My 71 Dodge demon race car only with removable fiberglass frontend with roll bar tied to the shock tower and frame rails was 1700lbs total weight was 2750 , no inner fenders either
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Big Block A-body front weights? [Re: mopowers] #2705524
10/10/19 01:08 PM
10/10/19 01:08 PM
It depends on how much aluminum parts are on your motor and if you installed it in a stock location, my old pump gas street Duster had 50.5 % on the front tires with the motor slid back one inch on the transmission mounts with elephant ears, the rear end was moved forward two inches also devil.
I've own a bunch of BB A body cars, stock BB 383 Darts and Baracuda are near 53 % on the front shruggy
Re: Big Block A-body front weights? [Re: 67mprfan] #2705817
10/11/19 09:47 AM
10/11/19 09:47 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks! This helps.
Re: Big Block A-body front weights? [Re: 67mprfan] #2705872
10/11/19 12:07 PM
10/11/19 12:07 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Dang, My '68 A-Body convertible Barracuda weighs 3700 lbs without me in it. I was shocked at how heavy the car is.
Re: Big Block A-body front weights? [Re: jbc426] #2706796
10/14/19 06:59 PM
10/14/19 06:59 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
My 75 duster drag only car weights 3140 with me in it (Im 150). 1780 on the front, 1360 on the back.
It is:
backhalved
10 pt cage with snout bars going to the front frame rails
inner fenders removed
440
alum heads, intake
727
Dana 60
Ladder bar
5 gal fuel cell
All steel and glass except fiberglass bumpers and the rear window is lexan
Front end has been changed to the 70-72 style (Hood, grill, bumper, etc)
Stock front end k frame, steering, brakes, etc.
Re: Big Block A-body front weights? [Re: DusterKid] #2710001
10/25/19 01:53 PM
10/25/19 01:53 PM
PA
moparacer Offline
moparacer  Offline
PA
68 Dart drag car. Backhalf with stock front. Fibreglass hood, trunk lid, and bumpers. Runs 5.70's 1/8 mile ets.
3035 total race weight. 1785 front and 1250.
Too front heavy IMO. Need to front half it over winter.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Big Block A-body front weights? [Re: moparacer] #2710005
10/25/19 02:06 PM
10/25/19 02:06 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Our hemi super stock cars are around 54-57% front end wht. @ 3200# with dr. Actually we would put weight in front to help calm down wheelies. I don't think there is much weight savings in front halving.
JAKES AUTOMOTIVE
Re: Big Block A-body front weights? [Re: JAKE68] #2710012
10/25/19 02:35 PM
10/25/19 02:35 PM
PA
moparacer Offline
moparacer  Offline
PA
I would be doing it for engine setback. It is 58-42 right now. Like to shift some weight to the rear.
Re: Big Block A-body front weights? [Re: moparacer] #2710019
10/25/19 04:31 PM
10/25/19 04:31 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
My 1968 Dart weighs 3250lb.s 55% front
I like it where it is. Wheelies are tough enough to control as it is. 5.40s in the 1/8th mile@135
Re: Big Block A-body front weights? [Re: Sammy] #2710031
10/25/19 06:33 PM
10/25/19 06:33 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It looks like the A body gains it weight advantage from the rear. My 64 Belvedere. Light bumper brackets (steel bumper), glass hood, aluminum -1 heads, Mega block, 2 carbs, light brakes, stock suspension, inner fenders, and fenders. 1810lbs on the nose w/driver (200). 54% @ 3350 lbs
Doug
Re: Big Block A-body front weights? [Re: mopowers] #2710039
10/25/19 07:44 PM
10/25/19 07:44 PM
You need to keep in mind hat the 108 wheel base cars are not exactly like the longer 110 W.B A body cars with the same motor on weight distribution :work;
My old pump gas Duster was right at 50.5% on the nose with me in it ready to race boogie I had moved the motor back right at 1.0 inch on the trans cross member and moved the rear end forward around 1.5 inches also devil wrench
Lots of ways to make any car better on the weight distribution whistling depending on how hard you want to work and how much money do you want to spend whistling work scope
Re: Big Block A-body front weights? [Re: mopowers] #2710044
10/25/19 08:03 PM
10/25/19 08:03 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Just weighted my Duster that went 6.08 in the 1/8th last week.....Here are the weights as the car sits without me in it! Wilwoods on all four corners..
Re: Big Block A-body front weights? [Re: Dragula] #2710069
10/25/19 10:22 PM
10/25/19 10:22 PM
UK
rb446 Offline
rb446  Offline
UK
Could you take a well educated guess please at the weight of my old '69 Cuda I ran back in the late 80's>1991>
unfortunately I never got to weigh it properly and was just trying to work out the motor's fwhp from mph/weight, would I be close@3300 with me being 196lbs, I believe fastbacks were heavy.
All steel apart from fibre bonnet, perspex side windows, lightened doors
6 point cage, not moly.
No inner wings, stock grill
smaller radiator, stock dash, wiper motor
stock front end+down bars
2 lightweight seats
frame ties
Backhalved 2x3" chassis
centr lines, 14x32's
440-6 block, 906's, ally intake, 4150 carb-727-8.3/4" spool
2.18" f/well hdrs
L/bars/coil-overs
large 50lbs battery in trunk+10lb N20 bottle
6 gal fuel cell, 2 x holley blue pumps.
[img][img]https://i.ibb.co/jrHh4n9/69-CUDA-AT-SPR.jpg[/img][/img]
thanks.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
