Whose 727 street/strip converters are you using? #2709518
10/23/19 01:24 PM
10/23/19 01:24 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I have the same Dynamic 9.5" that I bought in '99(?) and it's still in good shape given how little my car's been running over the years. However, it was spec'd for the car when it was making maybe 550 HP and running very low 11s. The converter still seemed to work well w/ the 50+ HP increase that put the car into the mid 10s, so I was happy.
However, the new engine is an easy 100+ HP more than the converter was spec'd for originally in '99. It's still going to be my baseline when the car is back together, but at some point I a$$ume it's either going to need to be re-configured for the new engine... or perhaps I'll want (need?) to change to another converter.
So, as my subject line states, whose 727 street/strip converters are you using? work
Re: Whose 727 street/strip converters are you using? [Re: BradH] #2709520
10/23/19 01:38 PM
10/23/19 01:38 PM
America
WedgeFED Offline
WedgeFED  Offline
America
http://www.tcsperformance.com/performance_converters/
have been good to us. good customer service and quality
Re: Whose 727 street/strip converters are you using? [Re: WedgeFED] #2709523
10/23/19 01:42 PM
10/23/19 01:42 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
PTC
72 Plymouth Roadrunner 11.08@123.25
Re: Whose 727 street/strip converters are you using? [Re: BradH] #2709549
10/23/19 02:58 PM
10/23/19 02:58 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The question is "how much torque does the new engine make at the observed stall speed?"
It may have less than the original engine (later intake closing = lower CCP) and will stall lower despite the higher peak power.
If the stall torque is higher, the stall speed will increase (duh) by the ratio of (new torque ÷ old torque)^.5
RPM = K × (T^.5)
Just using easy numbers:
Stall now 3,500, new torque 550, old torque 500
(550 ÷ 500)^,5 = 1.0488, × 3,500 = 3,671 RPM new stall
Stall now 3,500, new torque 600, old torque 500
Same math = 3,834 RPM new stall
Whether this helps or hurts launch...?
Boffin Emeritus
Re: Whose 727 street/strip converters are you using? [Re: BradH] #2709558
10/23/19 03:06 PM
10/23/19 03:06 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
PTC.
Ok
Re: Whose 727 street/strip converters are you using? [Re: polyspheric] #2709564
10/23/19 03:35 PM
10/23/19 03:35 PM
BradH Offline OP
BradH  Offline OP
RPM = K × (T^.5)
Converter flashed to ~4500 from 2000 launch w/ old engine combination, so I highlighted the #s at 4500 for comparison. Your formula shows about a 4600 stall w/ additional torque. shruggy
Re: Whose 727 street/strip converters are you using? [Re: BradH] #2709577
10/23/19 04:26 PM
10/23/19 04:26 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Brad ,
I ran a similar Dynamic/Lupo to you for years stalled around 48/4900 . This was with both 440 and 505 footbraking .
Now with transbrake I have a A1 Performance 8" unit , stalled at 5800 with original 505 and 440 . When I went TF270 head stall went to 6000 , but car went 0.25 faster so the heads obviously helped the motor HP wise.
Drives fine daily . Even drove to a race in Mildura on the other side of the state - 12 1/4 hours on the highway no dramas . Tis was 2 weeks ago .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Whose 727 street/strip converters are you using? [Re: tex013] #2709590
10/23/19 05:14 PM
10/23/19 05:14 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have loads of street miles on a Turbo Action 8" 4500 when I had my 727. My 904 had a 8" 4800 until the snout broke but that is getting repaired. The 4500 behind the 727 flashed to about 5500 and the 4800 with the 904 flashes to 6400. I did 5 drag weeks with the 727 converter and 1 with the 904, car weight on the road for drag week is around 4000ish.
The street manners of them don't bother me at all.
68 Barracuda Formula S 340
Re: Whose 727 street/strip converters are you using? [Re: Bad340fish] #2709598
10/23/19 05:52 PM
10/23/19 05:52 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
8" ATI Tree master about 18 yrs old with one refresh it has great street manners also
Re: Whose 727 street/strip converters are you using? [Re: BradH] #2709606
10/23/19 06:29 PM
10/23/19 06:29 PM
New York
polyspheric Offline
polyspheric  Offline
New York
That's not "my formula", it's the one the transmission and converter manufacturers use.
Boffin Emeritus
Re: Whose 727 street/strip converters are you using? [Re: polyspheric] #2709662
10/23/19 09:28 PM
10/23/19 09:28 PM
BradH Offline OP
BradH  Offline OP
Regardless, it calcs right at 100 RPM increase.
Know of any formula to help quantify converter slippage increase resulting from torque increase? It would be interesting to know if there is a way to help predict at what point you are likely to start "driving through" a known converter when the power level is stepped up.
Re: Whose 727 street/strip converters are you using? [Re: BradH] #2709664
10/23/19 09:37 PM
10/23/19 09:37 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Turbo Action or PTC, never had any issues with either one.
The only Carbs I care about are under the hood!
Re: Whose 727 street/strip converters are you using? [Re: Azzkikrcuda] #2709670
10/23/19 09:47 PM
10/23/19 09:47 PM
ma.
duspan Offline
duspan  Offline
ma.
ptc is very good,they have a mopar guy that is real good with converter combo!!!
Re: Whose 727 street/strip converters are you using? [Re: BradH] #2709679
10/23/19 10:08 PM
10/23/19 10:08 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi ,
the dynamic worked good for 20 years and you want to know where to get a converter ?
Re: Whose 727 street/strip converters are you using? [Re: calrobb2000] #2709705
10/24/19 06:29 AM
10/24/19 06:29 AM
BradH Offline OP
BradH  Offline OP
Originally Posted by calrobb2000
hi ,
My Dynamic has worked very well so far. My friend's sucked. Nobody hits 100%, and converter tech & good builders can change over 20 years. If the new engine and the old converter aren't a good match, I'd like to know what other people's experiences have been.
Re: Whose 727 street/strip converters are you using? [Re: BradH] #2709719
10/24/19 07:57 AM
10/24/19 07:57 AM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
When I bought my 8" vert from Dynamics I told them I wanted it to flash 5200. It was dead nuts 5200. Can't get any better than that.
Re: Whose 727 street/strip converters are you using? [Re: mopar dave] #2709731
10/24/19 09:15 AM
10/24/19 09:15 AM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
PTC
Mopar racer owned
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Whose 727 street/strip converters are you using? [Re: BradH] #2709733
10/24/19 09:16 AM
10/24/19 09:16 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
For my A518 I had PATC custom build mine, told them my engine combo & they nailed it, so far so good, 3500miles of abuse .
Re: Whose 727 street/strip converters are you using? [Re: Azzkikrcuda] #2709878
10/24/19 08:50 PM
10/24/19 08:50 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
ATI here......Getting one for a big engine like mine wasn't easy....Love it.
Re: Whose 727 street/strip converters are you using? [Re: Dragula] #2709926
10/25/19 07:39 AM
10/25/19 07:39 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
FTI - great Service! Switched from a 9.5" PTC with 3200 stall to a 9.5" FTI with 3500 stall. Day and night difference! Much better.
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
