Re: 7 sec car Radiator [Re: Raffaplymouth60] #2708565
10/20/19 02:39 PM
10/20/19 02:39 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Is it possible that you have air trapped in the cooling system? Looks like the highest point is the thermostat housing. maybe needs a bleed screw to just to be purged the air out of the system?
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: 7 sec car Radiator [Re: racerhog] #2742003
02/11/20 04:12 PM
02/11/20 04:12 PM
Italy
Raffaplymouth60 Offline OP
Italy
Hello Guys ! i bought a new Big Radiator... im working for installation... but also with this the water neck look like a little bit higher than radiator ... i hope can make air in the circuit ... im also undecided if put a reservoir tank or not ?
1970 Cuda 496 street driven 9.22@150
1971 Demon 572 7.82@176
1957 Desoto Adventurer Convertible 345 Hemi
1958 Plymouth Fury Christine
2008 Dodge Ram 1500 Hemi
1970 Dodge ChallengerRT 6pack 4 speed 1 of 135
1968 Dodge Charger RT 4 speed
Re: 7 sec car Radiator [Re: Raffaplymouth60] #2742752
02/14/20 09:06 AM
02/14/20 09:06 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I'm going to mention the obvious so i dont hope to insult anyone here. I see both radiator have the inlet and outlet on the same tank...I'm going to assume that these are both crossflow radiators otherwise water will follow the least path of resistance.
Re: 7 sec car Radiator [Re: HardcoreB] #2742814
02/14/20 11:52 AM
02/14/20 11:52 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
If you look carefully you can see the dividers in the tanks.
Re: 7 sec car Radiator [Re: Skeptic] #2742978
02/14/20 09:03 PM
02/14/20 09:03 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
The beginning of round robin is reality. So, ultimate cool downs are a fantasy. Especially with my one man crew: me. I stage at a temp that my cooling system can deal with on that day. Some weekends it’s 110, others, 140.
Re: 7 sec car Radiator [Re: Raffaplymouth60] #2743163
02/15/20 12:14 PM
02/15/20 12:14 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
OK, I know the coffee hasn't kicked in when my brain sees the post title and translates it as "7 sec car Radio"... coffee
Re: 7 sec car Radiator [Re: BradH] #2746160
02/24/20 04:49 PM
02/24/20 04:49 PM
Italy
Italy
Hello , got is now hoses and new billet water neck filler .... is a little bit higher than the radiator ... i hope no more air inside.. expansion tank will be from water filler , i installed 25lb cap in the radiator and 19 lb cap on the filler
Re: 7 sec car Radiator [Re: Raffaplymouth60] #2746336
02/25/20 08:47 AM
02/25/20 08:47 AM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
My junk runs mid to low 8s, I run a cheap summit brand one,i think it’s for a camaro or something. 3 core, mounted under the trunk floor, Taurus fan, meziere electric pump. Can cruise all day never gets over 170-180
Re: 7 sec car Radiator [Re: 1980volare] #2746342
02/25/20 09:27 AM
02/25/20 09:27 AM
an8sec70cuda Offline
Apples to oranges here. A new style engine w/ a turbo won't build nearly the amount of heat as the OP's engine will. I have several friends w/ GM LS powered turbo cars that are FAST and the cooling systems they use (like yours) make me jealous, lol.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 7 sec car Radiator [Re: an8sec70cuda] #2746376
02/25/20 11:52 AM
02/25/20 11:52 AM
Italy
Italy
This is 7.80 car ,with 350 of nitrous shot , in italy in the summer ... 95/100 f
