Page 3 of 4 1 2 3 4
Re: Baby Steps Progress Report [Re: BradH] #2702578
10/01/19 11:28 AM
10/01/19 11:28 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
A couple of minor things... Decided the heads are going back up to Dwayne's after I started having cold sweats over the possibility of somebody else doing a sub-par job.
Also, didn't like the raw fuel trail that was showing in the bowls behind the valve guides, so I went over the bowls & runner surfaces (but not the short turns) and put a bit o' texture on them to help w/ fuel fallout issues. Or so the theory goes... whistling
Bowl pic is "before" w/ the fuel trail highlighted; runner pic shows surface texture applied.
Re: Baby Steps Progress Report [Re: BradH] #2702601
10/01/19 12:44 PM
10/01/19 12:44 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I seem to remember sending someone a set of atage 6’s where I had left the intake runners roughed up....... and they didn’t like it, so they polished them smooth.
Maybe it’ll come back to me who that was.......work
Re: Baby Steps Progress Report [Re: fast68plymouth] #2702650
10/01/19 02:49 PM
10/01/19 02:49 PM
BradH Offline OP
BradH  Offline OP
Hmmm... let me know if you remember. Whomever it was, I'm sure he's an idiot. whistling
Re: Baby Steps Progress Report [Re: BradH] #2702677
10/01/19 04:45 PM
10/01/19 04:45 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
Back when I did port work I would blast the port in the direction of flow with Black Magic abraisive , I really dont know if it helped or not, but after blasting the port flowed a little more.
Re: Baby Steps Progress Report [Re: BradH] #2702684
10/01/19 04:55 PM
10/01/19 04:55 PM
You won't be the first idiot that smooth up the intake port walls making the fuel droplets congeal and drop out and make the motor less efficient whistling shruggy
Re: Baby Steps Progress Report [Re: BradH] #2702700
10/01/19 05:33 PM
10/01/19 05:33 PM
BradH Offline OP
BradH  Offline OP
Oh, I forgot to add riblets to the SSRs! grin
Re: Baby Steps Progress Report [Re: BradH] #2702710
10/01/19 06:34 PM
10/01/19 06:34 PM
So. Burlington, Vt.
So. Burlington, Vt.
Once they leave my possession, what happens to them is beyond my control smoke
I thought riblets was something McD’s used to have....... with bbq sauce on a bun.
Re: Baby Steps Progress Report [Re: fast68plymouth] #2702715
10/01/19 06:44 PM
10/01/19 06:44 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I think that was the McRib Dwayne.
Re: Baby Steps Progress Report [Re: fast68plymouth] #2702906
10/02/19 09:18 AM
10/02/19 09:18 AM
BradH Offline OP
BradH  Offline OP
I feel the same way about my oldest son now that he's gone off to college.
I'll have to look and see if McDonald's is listed as one of the contributors on the research papers I've read about fluid flow over various surface textures. scope However, I don't recall sesame seeds being one of the surface textures tested.
Re: Baby Steps Progress Report [Re: BradH] #2703808
10/04/19 01:05 PM
10/04/19 01:05 PM
So. Burlington, Vt.
So. Burlington, Vt.
Re: Baby Steps Progress Report [Re: fast68plymouth] #2704353
10/06/19 03:22 PM
10/06/19 03:22 PM
BradH Offline OP
BradH  Offline OP
The only update is the heads are now in FedEx's hands to go back to PRH to fix my eff-ups.
Re: Baby Steps Progress Report [Re: BradH] #2706162
10/12/19 11:36 AM
10/12/19 11:36 AM
BradH Offline OP
BradH  Offline OP
Heads are fixed and will be on the way back to me Monday. Everything else has come to a halt until I get my schedule figured out for the next steps.
Re: Baby Steps Progress Report [Re: BradH] #2707630
10/17/19 12:42 PM
10/17/19 12:42 PM
BradH Offline OP
BradH  Offline OP
Heads are back.
That is all / carry on / smoke if ya' got 'em / nothing to see here folks...
Re: Baby Steps Progress Report [Re: BradH] #2707747
10/17/19 04:59 PM
10/17/19 04:59 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
Brad, I can really appreciate your frustration with th Victor heads. After looking at the pictures of the combustion chambers on your heads, I realized that the ones on mine appear somewhat different on the quench side of the chamber. Is there a production design change over the years, or is this what you have developed. Just happened to realize the difference. Ran into similar problems with losing effective rocker arm lift, going to B3 geometry correction. Hughes 1.5 rockers actually effectively turned into 1.45 & 1.43 ratios. Valve scrub was now correct but had to opt for 1.6 rockers to bring valve lift back into perspective. They actually come in at 1.55 & 1.53. Had lost valve lift in another area, so it became a new cam or rocker decision.Cam reportedly perfomed very well in a different vehicle so I opted change rockers. I can feel your pain with these heads. It deffinitely wasn't in the brochure.I hope we both get to where we want to be ,performance-wise. Good luck!! Bill
Re: Baby Steps Progress Report [Re: lancer493] #2707755
10/17/19 05:41 PM
10/17/19 05:41 PM
So. Burlington, Vt.
So. Burlington, Vt.
Brads motor sure didn’t seem like it was having any issues on the dyno when it was making nearly 700hp at about 7k.
Well.......nothing related to anything mechanical.
I thought the overall package worked pretty well.
Some of the carbs we tested weren’t up to snuff though.
Now........ the amount of porting required just to get the bowls sized close to anything appropriate for the 2.20/1.81 valves in the gen 2 std port version heads....... that’s another story.
Re: Baby Steps Progress Report [Re: fast68plymouth] #2707756
10/17/19 05:43 PM
10/17/19 05:43 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Happy to hear you are making progress hombre.
So we are going racing this spring, correct? : D
I want to see that hood scoop gulp some air!
Then you can spray it! (Kidding...okay not really)
Re: Baby Steps Progress Report [Re: lancer493] #2707840
10/17/19 08:42 PM
10/17/19 08:42 PM
BradH Offline OP
BradH  Offline OP
Yeah, the early Victor heads had a different shape to the quench area. As Dwayne mentioned, the early heads also required a lot less work to get the ports (bowls) sized within reason.
Re Dwayne's other comments... NONE of my dyno carbs were close on the tune. I went through them all and sent three down to AED to be wet-flow tested. AED did some work on one, and I changed the tunes on the other two based on their test results.
Other than the carb setups, the irritating oil leaks and the coolant leaks from the MLS head gaskets, the engine "could" have been run as it was dynoed. However... I got major OCD over some things about the valve train that Dwayne wasn't phased by at all. End result has been more down time, more money spent, and all for something that 20/20 hindsight says wasn't worth getting so bent outta shape over.
So here I am ten years after the car last ran and two years since the engine was dynoed trying to put it all together again. wrench
Re: Baby Steps Progress Report [Re: BradH] #2707889
10/17/19 11:20 PM
10/17/19 11:20 PM
Pattison Texas
Pattison Texas
Thanks for the updates !!
Re: Baby Steps Progress Report [Re: CSK] #2707891
10/17/19 11:49 PM
10/17/19 11:49 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
Keep at it!! missed it what type of car?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Baby Steps Progress Report [Re: Stroker Scamp] #2707912
10/18/19 05:44 AM
10/18/19 05:44 AM
BradH Offline OP
BradH  Offline OP
What it looked like as a mid-to-high 10-sec ride...
Page 3 of 4 1 2 3 4
