62-65 b body auto trans mount dimensions???
#2707372
10/16/19 08:01 PM
10/16/19 08:01 PM
Posts: 1,572 wisconSIN
Blown61
wisconSIN
anyone have one laying around that could tell me the distance from the top of the mount where it bolts to trans to the bottom where it bolts to xmember?
Thanks!
Re: 62-62 auto trans mount dimensions???
[Re: Blown61]
#2707392
10/16/19 08:49 PM
10/16/19 08:49 PM
RapidRobert
my early (63-66) early A body Energy Suspension "poly" trans mount is 3&3/8" & from what I understand auto & manual are the same. EDIT I looked it up & this one fits 1962-1973 Dart (so I would assume fits the other A bodies of those years).
[Re: RapidRobert]
#2707405
10/16/19 09:22 PM
10/16/19 09:22 PM
RapidRobert
Oh I missed that you said B body. I would go to www.energysuspension.com & hit "download catalog" then scroll down to page 36 & the # is 5.1112 & it has the apps that it fits & it includes some B bodies (not sure if back to 62 or not) I bought mine for an early A body & from top to bottom (not including the stud) is 3&3/8" on the nose. EDIT I went back over there & it fits 62-70 Belvedere
[Re: RapidRobert]
#2707409
10/16/19 09:35 PM
10/16/19 09:35 PM
Blown61
wisconSIN
Oh I missed that you said B body. I would go to www.energysuspension.com & hit "download catalog" then scroll down to page 36 & the # is 5.1112 & it has the apps that it fits & it includes some B bodies (not sure if back to 62 or not) I bought mine for an early A body & from top to bottom (not including the stud) is 3&3/8" on the nose. EDIT I went back over there & it fits 62-70 Belvedere Thanks again!!!
[Re: RapidRobert]
#2707449
10/17/19 12:09 AM
10/17/19 12:09 AM
Posts: 43,305 Bend,OR USA
Cab_Burge
1962 Dart where bodies, not A bodies ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) 1963 and later Darts where A bodies ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) The 1960 to 1962 Mopar A bodies came in two different brands, Chrysler Lancers, maybe Dodge ?????? (CRS ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) ), no Plymouth A bodies from 1960 to 1962. the Hyper pack slant six with the four barrel and four speeds started in 1960 or 1961,the 273 LA motors where introduced in mid year 1964 with the single exhaust and two barrel carbs only for the rest oft hat year I what I remember I think they added the four barrel, bigger cam and higher compression ratio in the beginning of 1965 on the 273 in both brands of the A body , not late 1964 ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: Cab_Burge]
#2707631
10/17/19 12:46 PM
10/17/19 12:46 PM
RapidRobert
1962 Dart were B bodies, not A bodies. You're right
[Re: topside]
#2708351
10/19/19 03:46 PM
10/19/19 03:46 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Actually no B bodys in 62 IIRC first B body was 65.Rocky
Chrysler Firepower
[Re: therocks]
#2708360
10/19/19 04:32 PM
10/19/19 04:32 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Mopar Performance catalog shows B-body as '62-'79.
[Re: John_Kunkel]
#2708453
10/20/19 08:41 AM
10/20/19 08:41 AM
therocks
Niles , Ohio
We know MP could never screw up.IIRC first b designation was 65.Rocky
Chrysler Firepower
[Re: Blown61]
#2708790
10/21/19 10:03 AM
10/21/19 10:03 AM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
so, anyone have the dimensions for a 62-65 b body trans mount? I just removed one yesterday from a 65 Bel II auto car... Everything looks to be original and unmolested from a 69,000 mile car... Two studs on the bottom of the mount thru the crossmember... The distance from the inside of the bottom of the crossmember to mounting flange for the transmission is 2 15/16"...
...FAFO...
[Re: skicker]
#2708873
10/21/19 01:44 PM
10/21/19 01:44 PM
Blown61
wisconSIN
so, anyone have the dimensions for a 62-65 b body trans mount? I just removed one yesterday from a 65 Bel II auto car... Everything looks to be original and unmolested from a 69,000 mile car... Two studs on the bottom of the mount thru the crossmember... The distance from the inside of the bottom of the crossmember to mounting flange for the transmission is 2 15/16"... AWESOME!!! thank you very much!!
