RacePak Dash vs. Holley Stand Alone Dash
#2706472
10/13/19 07:24 PM
10/13/19 07:24 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
Anyone try the Holley stand alone. Figured the software and such would be easy to use, but it seems rather new.
Looking to put somthing in my Street Strip car....
Re: RacePak Dash vs. Hplley Stand Alone Dash
[Re: Dragula]
#2706475
10/13/19 07:36 PM
10/13/19 07:36 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
I have the Holley 7" dash, it can be used stand alone or with Holley EFI, I have mine with EFI, it is AWESOME, you can take a blank screen & build a dash like you want & need. the ONLY thing is I have to wear my cheater reading glasses because I have so much on the dash.
[Re: Dragula]
#2706485
10/13/19 08:23 PM
10/13/19 08:23 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Looking to put somthing in my Street Strip car.... Do you have anything now?
[Re: hemi-itis]
#2706508
10/13/19 09:22 PM
10/13/19 09:22 PM
Dragula
Monster Tach,Sun pro oil pressure, water temp, and volt meter with a GoPro.....and an AFR gauge....How's that?
[Re: AndyF]
#2706604
10/14/19 07:30 AM
10/14/19 07:30 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
The Holley Dashes look super nice! The only issue I have with any dash like that is trusting the tachometer. I like an analog one so much I am not sure I could shift off of a dash. I don't do well with a shift light either but that is just me.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2706676
10/14/19 12:08 PM
10/14/19 12:08 PM
hemi-itis
I took the monster tack off the top of the dash when I put a new dash pad on,replaced it with a shift light. Does the Holley deal data log? I spent close to $3k for the race pak logger dash.Picked up a 1/2 second just by seeing my AFR. I also found the the wall with IAT where the power goes flat! Time for am intercooler
[Re: hemi-itis]
#2706682
10/14/19 12:31 PM
10/14/19 12:31 PM
CSK
Pattison Texas
Yes the Holley Data Logs.
[Re: CSK]
#2706850
10/14/19 10:15 PM
10/14/19 10:15 PM
hemi-itis
If your using Holley EFI it's a no brainer. Still need to install all the sensors.I do like the holly dash better than the race pak.
