Re: 7 sec car Radiator
[Re: Raffaplymouth60]
#2708565
10/20/19 02:39 PM
10/20/19 02:39 PM
Posts: 452 Monrovia, So-Cal, USA
racerhog
Is it possible that you have air trapped in the cooling system? Looks like the highest point is the thermostat housing. maybe needs a bleed screw to just to be purged the air out of the system?
Bob(Cowboy)Hogan Monrovia So-Cal
[Re: racerhog]
#2742003
02/11/20 04:12 PM
02/11/20 04:12 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Hello Guys ! i bought a new Big Radiator... im working for installation... but also with this the water neck look like a little bit higher than radiator ... i hope can make air in the circuit ... im also undecided if put a reservoir tank or not ?
1970 Cuda 496 street driven 9.22@150 1971 Demon 572 7.82@176 1957 Desoto Adventurer Convertible 345 Hemi 1958 Plymouth Fury Christine 2008 Dodge Ram 1500 Hemi 1970 Dodge ChallengerRT 6pack 4 speed 1 of 135 1968 Dodge Charger RT 4 speed
[Re: BradH]
#2746160
02/24/20 04:49 PM
02/24/20 04:49 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Hello , got is now hoses and new billet water neck filler .... is a little bit higher than the radiator ... i hope no more air inside.. expansion tank will be from water filler , i installed 25lb cap in the radiator and 19 lb cap on the filler
[Re: 1980volare]
#2746342
02/25/20 09:27 AM
02/25/20 09:27 AM
Posts: 13,524 Marion, South Carolina [><]
an8sec70cuda
My junk runs mid to low 8s, I run a cheap summit brand one,i think it’s for a camaro or something. 3 core, mounted under the trunk floor, Taurus fan, meziere electric pump. Can cruise all day never gets over 170-180 Apples to oranges here. A new style engine w/ a turbo won't build nearly the amount of heat as the OP's engine will. I have several friends w/ GM LS powered turbo cars that are FAST and the cooling systems they use (like yours) make me jealous, lol.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#2746376
02/25/20 11:52 AM
02/25/20 11:52 AM
Posts: 195 Italy
Raffaplymouth60
Italy
This is 7.80 car ,with 350 of nitrous shot , in italy in the summer ... 95/100 f
