7 sec car Radiator #2705583
10/10/19 03:40 PM
10/10/19 03:40 PM
Italy
Raffaplymouth60 Offline OP
Italy
i would know which radiator is correct for a 7 second car ... my engine is 572 nitrous .. if start the pass at 140 degree al is ok finish line at 210 ... if start at 170 ... finish line at 230 .. need new aluminium bigger radiator ? no air from the grille ....
1970 Cuda 496 street driven 9.22@150
1971 Demon 572 7.82@176
1957 Desoto Adventurer Convertible 345 Hemi
1958 Plymouth Fury Christine
2008 Dodge Ram 1500 Hemi
1970 Dodge ChallengerRT 6pack 4 speed 1 of 135
1968 Dodge Charger RT 4 speed
Re: 7 sec car Radiator [Re: Raffaplymouth60] #2705632
10/10/19 05:36 PM
10/10/19 05:36 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'd try a bigger fan first since the front is closed off.
Re: 7 sec car Radiator [Re: Raffaplymouth60] #2705645
10/10/19 06:11 PM
10/10/19 06:11 PM
Washington
madscientist Offline
Washington
That much temp gain in that short time says your radiator is WAY TOO SMALL and your water pump doesn't flow enough. You have enough airflow moving down the track that the fan isn't a factor.
Re: 7 sec car Radiator [Re: madscientist] #2705661
10/10/19 06:55 PM
10/10/19 06:55 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
By the time it gets hot your going to shut it off 😛
Re: 7 sec car Radiator [Re: FastmOp] #2705712
10/10/19 09:45 PM
10/10/19 09:45 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
That much gain that quick is not the radiators fault. Are you running the thing lean? Timing slow? You can usually see the difference in the temperature gauge by moving the jetting a few numbers one way or the other.
Re: 7 sec car Radiator [Re: FastmOp] #2705714
10/10/19 09:49 PM
10/10/19 09:49 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
You're effectively pulling air through about 1/2 of the core.
Something that moves the fan back and incorporates a shroud like the HHR fans will make a difference.
Just circulating coolant through it and not transferring some of the heat to passing air doesn't help much.
Re: 7 sec car Radiator [Re: tubtar] #2705779
10/11/19 07:30 AM
10/11/19 07:30 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
why are you starting so high ?
my car I try to roll through the water at 90-100
stage at 110-120
return road usually 145
If you look at a lot of heads up racers, they have small rads to save weight. If using a small rad and it doesn't have the capacity, just start lower.
As long as it comes up on the trans brake, your good
....BAD A$$ STREET CAR.....
Re: 7 sec car Radiator [Re: n20mstr] #2705854
10/11/19 11:30 AM
10/11/19 11:30 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
This would be my first question....My car goes in as cold as possible, they make more power this way too(cold water, warm oil). You could use a shroud as that will make sure you have airflow across the entire radiator. I use a small sirocco style radiator with a shroud and my car only sees over 140 when my opponent takes forever to stage ie turbo guy. My car runs low 7's N/A
Re: 7 sec car Radiator [Re: justinp61] #2705942
10/11/19 03:27 PM
10/11/19 03:27 PM
Italy
Italy
yep
..this was my idea... two fans ..but im undecided if try also bigger radiator
Re: 7 sec car Radiator [Re: FastmOp] #2705944
10/11/19 03:31 PM
10/11/19 03:31 PM
Italy
Italy
yep ! but the problem is when pass is close ! no time for make cold !
Re: 7 sec car Radiator [Re: CMcAllister] #2705946
10/11/19 03:34 PM
10/11/19 03:34 PM
Italy
Italy
no Lean... and very Fast ... a little bit rich ... best ET is 7.82@175
Re: 7 sec car Radiator [Re: n20mstr] #2705947
10/11/19 03:38 PM
10/11/19 03:38 PM
Italy
Italy
stage at 110-120
you right ... but is from a pass and another pass is 15 minute .. no time for make cold ... i started minimum at 120 .. i can start at 90 ? but some time for wait before burnout go fast from 100 to 140 ...
Re: 7 sec car Radiator [Re: Raffaplymouth60] #2705948
10/11/19 03:45 PM
10/11/19 03:45 PM
Italy
Italy
https://youtu.be/WWxrBGgS1kI
you can see the water gauge on lower .. the second from right side
Re: 7 sec car Radiator [Re: Raffaplymouth60] #2705954
10/11/19 04:05 PM
10/11/19 04:05 PM
Italy
Italy
DEMON 572
Re: 7 sec car Radiator [Re: Raffaplymouth60] #2705959
10/11/19 04:17 PM
10/11/19 04:17 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
C & R Racing 317-293-4100 Radiators https://www.crracing.com/
Ron Davis Radiators 623-877-5000 http://www.rondavisradiators.com/
Either of these would be good
2011 Drag Pak Challenger
Re: 7 sec car Radiator [Re: Raffaplymouth60] #2705961
10/11/19 04:24 PM
10/11/19 04:24 PM
N
n20mstr Offline
n20mstr  Offline
N
stage at 110-120
Take a note from Stock/Super stock guys. Take you upper hose off rad, dump 5 gals in there and let it come out the top of the rad. If you want rig up a hose that you can slip on the rad, and let the water flow into a bucket. OR get real creative and use two buckets with a pump, fill one 5 gal and use a pump to pump it through the engine and into another empty 5 gal bucket. Cheap mans chiller
You can get a cheap digital gauge from Jegs or Summit that goes down real low. Mine was 50* this past weekend. Now you can make sure you are 90* in the lanes.
Don't know if you are, but towing up helps a lot.
YOu have paired exh on your engine, that's a hot spot you don't need for nitrous use, run it cool even if just for that reason
Re: 7 sec car Radiator [Re: Raffaplymouth60] #2706013
10/11/19 06:46 PM
10/11/19 06:46 PM
AndyF Online content
AndyF  Online Content
Maybe consider putting a small duct for air from the grill. At you speeds you won't need much. One 3 inch hole in the grill could feed a lot of air to the radiator.
Re: 7 sec car Radiator [Re: AndyF] #2706039
10/11/19 08:59 PM
10/11/19 08:59 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mine is completely closed off as well with no issues. My Cuda was closed up as well with a tow row sirocco radiator an even hot lapping it NEVER saw 190. Fwiw my Cuda went 7.94 171 NA at 29752
Re: 7 sec car Radiator [Re: Raffaplymouth60] #2706251
10/12/19 07:12 PM
10/12/19 07:12 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
1 question comes to mind..... Do you have or are you using a flow restrictor in the thermostat housing?
Also, Double check and make sure you have good flow and the Pump is flow well.
I think I would also check the inlet and outlet flow of the radiator. Some of these radiators are really slow flowing from very small tubes.
Keep chipping at it Raffa.... Looking good smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: 7 sec car Radiator [Re: racerhog] #2708349
10/19/19 03:16 PM
10/19/19 03:16 PM
Italy
Italy
Hola Hog ! i don't have any restrictor in the pump !
