Re: Turn Signal Trouble [Re: RapidRobert] #2708344
10/19/19 02:56 PM
10/19/19 02:56 PM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
YIKES!
I just noticed that the map light comes on when I press the brake pedal.[censored]?
Going to have to dive deep into this one.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Turn Signal Trouble [Re: RSI700VIPER] #2708480
10/20/19 10:33 AM
10/20/19 10:33 AM
moparx Online content
moparx  Online Content
that's NOT good.
beer
Re: Turn Signal Trouble [Re: RSI700VIPER] #2708492
10/20/19 11:01 AM
10/20/19 11:01 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Originally Posted by RSI700VIPER
YIKES!
If the dome light goes on when stepping on the brake pedal of a 67 GTO, that means the brake light fuse is blown. Could just be something similar.
Re: Turn Signal Trouble [Re: moparx] #2708493
10/20/19 11:02 AM
10/20/19 11:02 AM
NW New Jersey
NW New Jersey
Interior lights only come on when both fuses are blown. I replaced the fuses and now I'm back to square 1. Everything works fine except left blinker. Keeping it on blows the fuses. The dash wire harness has never been cut or messed with and I clean the bulkhead connectors with contact cleaner from time to time. I'm going to start off by replacing the directional switch in the column. I guy I met at a show yesterday said he had a similar problem and it was the directional switch. I see many after market switches out there. Can someone recommend a good source?
Re: Turn Signal Trouble [Re: RSI700VIPER] #2708681
10/20/19 10:02 PM
10/20/19 10:02 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Yeah, weird things can happen at the directional switch.
If this helps illustrate my comment: A guy told me in traffic one day that the left rear brake light wasn't working on my '67 Satellite. Turns out the screw holding the directional switch stalk got loose inside the steering column. The force of gravity on the loose directional stalk moved it downward close enough to the 'Left Turn' detent, that it cut power to the left tail light but ONLY WHEN BRAKING. Weird but true. All I had to do was tighten the stalk screw and the problem was fixed.
Best, - Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
