Engine diaper #2704823
10/08/19 11:06 AM
10/08/19 11:06 AM
Indianapolis Indiana
Jamie340 Offline OP
Jamie340  Offline OP
Looking for suggestions on engine diaper, for a 1971 Demon340.
Something light weight and user friendly.
Re: Engine diaper [Re: Jamie340] #2704828
10/08/19 11:15 AM
10/08/19 11:15 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
J&J diapers if you get the heat resistant one is maybe 3/16 of an inch at most on the sides and can lay right on the headers. My son and I both run them.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Engine diaper [Re: pittsburghracer] #2704833
10/08/19 11:23 AM
10/08/19 11:23 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
I have had very good luck with DRE, Dennis has always been responsive to any requests for custom stuff and gets it done in a timely manor. Unfortunately we have performance tested a couple of them and zero issues
Re: Engine diaper [Re: Al_Alguire] #2704979
10/08/19 09:14 PM
10/08/19 09:14 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Those guys are awesome....
Re: Engine diaper [Re: Jamie340] #2704990
10/08/19 09:48 PM
10/08/19 09:48 PM
ma.
roadrunner34 Offline
ma.
Nothing to complain about with the DRE diapers.
Re: Engine diaper [Re: Al_Alguire] #2705001
10/08/19 10:16 PM
10/08/19 10:16 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Thanks for your R&R Al whiney
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Engine diaper [Re: hemi-itis] #2705011
10/08/19 10:43 PM
10/08/19 10:43 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I like DJ too. I run DJ, and Stroud on my own stuff.
I have taken some plain single layer generic ones and made them custom for buds on tight budgets.
I know this sounds red neck, but it works. Cut some .032 aluminum sheet that matches the side profile of the diaper. Glue it to the outside of the diaper with high temp RV. Then you can bend it to fit the sides of the motor rigidly, and if the header touches no big deal. Sometimes I'll glue a piece inside the bottom to keep them from sagging.
Re: Engine diaper [Re: dthemi] #2705468
10/10/19 10:31 AM
10/10/19 10:31 AM
Jamie340 Offline OP
Jamie340  Offline OP
How do these manufacture deal with the drag link issues?
Jamie
Re: Engine diaper [Re: Jamie340] #2707240
10/16/19 11:18 AM
10/16/19 11:18 AM
Georgia and Washington
JMCarter Offline
JMCarter  Offline
Curious about the drag link question as well. Anyone?
Re: Engine diaper [Re: JMCarter] #2707248
10/16/19 11:38 AM
10/16/19 11:38 AM
PA.
"Little"John
"Little"John
PA.
All I can say again is my son has the diaper I recommend on his stock frontend small block Duster and is running one. We had more clearance issues with the Milidon oil pan and the 1 7/8 Hedmen headers but a 4 pound hammer fixed that.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Engine diaper [Re: JMCarter] #2707314
10/16/19 04:22 PM
10/16/19 04:22 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have a Russler II engine diaper, custom made at a generic price. He called me twice about the measurments just to make sure it would fit, and it fits like a glove.
https://russlerii.com/
My tie rods go through the oil pan sump. The diaper uses Velcro strips to attach flaps after the diaper is installed. I tested the diaper this spring when I broke a rod, going through the lights, very little oil leaked. It did dump some water as per the hole above the diaper as the rod broke the side of the block. But I felt no loss of traction and got the car stopped, track was only shut down a few minutes.
Re: Engine diaper [Re: jwb123] #2707384
10/16/19 08:20 PM
10/16/19 08:20 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I have a Russler II diaper as well. Fit extremely nice. He'll make whatever you need.
69 GTX 68 Road Runner
