Re: How to lock harmonic balancer
[Re: 1970GTX]
#2704981
10/08/19 09:21 PM
10/08/19 09:21 PM
RapidRobert
Use the piston TDC stop tool, its cheap
[Re: 1970GTX]
#2705010
10/08/19 10:40 PM
10/08/19 10:40 PM
RapidRobert
have the piston coming up on the compression stroke (so the valves will be closed) then feed in enough of the rope
[Re: 1970GTX]
#2705030
10/09/19 01:16 AM
10/09/19 01:16 AM
Posts: 43,284 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#2705051
10/09/19 07:56 AM
10/09/19 07:56 AM
RWG75
RWG75
For breaking it loose I've always used one of the power steering brackets. Use one of the crank pulley bolt holes and one of the water pump bolt holes. Should work for tightening down as well. Generally what I do is crank it down as tight as I can until the motor starts turning then spin the motor around a least once. Fully assembled engine in car with the spark plugs in. Centrifugal force will do the rest after ya fire it up.
[Re: SportF]
#2705133
10/09/19 11:19 AM
10/09/19 11:19 AM
RapidRobert
I glue a plastic vac cap on the end of the TDC stop to avoid nicking the piston (& I come up on the piston easy)
[Re: SportF]
#2705293
10/09/19 08:33 PM
10/09/19 08:33 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
Per SportF
Torque Converter starter gear and wedge
Exactly what I did on my rebuild a few years ago
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: Stanton]
#2705467
10/10/19 10:31 AM
10/10/19 10:31 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
if engine is on car... remove the flywheel access plate and put a socket with maybe a cloth between bolt head and socket to hold it in place by some pressure on one of the bolts, spin it untill meet with block and that will stop it. It has worked for me
[Re: NachoRT74]
#2705479
10/10/19 11:00 AM
10/10/19 11:00 AM
Posts: 8,033 Tulsa OK
Bad340fish
Tulsa OK
Doesn't work for torquing but for removal use a breaker bar and push it against the frame, then bump starter.
I always just impact them tight.
68 Barracuda Formula S 340
[Re: 5thAve]
#2705718
10/10/19 10:07 PM
10/10/19 10:07 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I would not use the piston stop on a big block. The angle is too shallow and close to dwell point.
Love the flat bar idea, 2 or 3 holes will absolutely hold things still. Especially in a shear. I'd aim for bolts 1 and 3 or 1, 2 and 3, 4 or 1 and 3. Just not 2 beside each other.
Or the flywheel teeth. I mean not blindly jambing something in there but a chunk of soft metal like aluminum will not hurt any teeth. I've done this many times with a large screwdriver or prybar. Just understand how to get it stuck so the load is square to a tooth.
[Re: Sniper]
#2705731
10/10/19 10:40 PM
10/10/19 10:40 PM
Posts: 3,482 Cold Spring, NY
1970GTX
Cold Spring, NY
about three foot of 3/8" nylon rope fed into a spark plug hole will do it. Just don't put all the r0pe in or you'll be trying to figure out how to get it out. I ended up using the rope method, it worked perfect. The intake was off, so I had an easy visual reference to make sure the valves were closed Thank you Sniper, Robert and everyone else for your suggestions.
[Re: Bad340fish]
#2706063
10/11/19 10:46 PM
10/11/19 10:46 PM
Posts: 4,957 WI
Dcuda69
WI
I always just impact them tight. Yep. Been doing it for over 30 years without issue.
[Re: 1970GTX]
#2706070
10/11/19 11:12 PM
10/11/19 11:12 PM
Bad340fish
Tulsa OK
about three foot of 3/8" nylon rope fed into a spark plug hole will do it. Just don't put all the r0pe in or you'll be trying to figure out how to get it out. I ended up using the rope method, it worked perfect. The intake was off, so I had an easy visual reference to make sure the valves were closed Thank you Robert and everyone else for your suggestions. While the rope method works and it is highly unlikely you would have a problem crap does happen. A drag week friend of mine used the rope method on a big block ford and somehow managed to get the rope knotted up in the cylinder. He had all kinds of hell getting it out and was very close to the point of having to take the motor apart! Unlikely but it does happen lol.
