70 E body ECS vapor line bulkhead part number help #2703182
10/02/19 07:40 PM
10/02/19 07:40 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
The combined 70-71 Mopar Parts Manual stinks.
Tryng to find the Mopar part number for the item pictured below. Just the plate or the assembly. The grommets have part numbers and even the foam gasket has a part number but the plate (or assembly) isn't shown in the parts manual.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: 70 E body ECS vapor line bulkhead part number help [Re: 71TA] #2703339
10/03/19 09:31 AM
10/03/19 09:31 AM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Hoovers, that makes the reproduction versions of these has the Mopar number 3404675 associated with this part but that number doesnt exist in the 70/71 parts manual. More than likely it is a 3404...number.
Re: 70 E body ECS vapor line bulkhead part number help [Re: 71TA] #2703807
10/04/19 01:05 PM
10/04/19 01:05 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
First off this is not an ECS part. It's the non-ECS part.
I have a 70 only parts book and for some reason it only lists this tube for station wagons. It's under section 14-86-50 of the parts book.
