Re: AC ?? [Re: Sniper] #2703431
10/03/19 02:44 PM
10/03/19 02:44 PM
Halifax, VA.
moparjack44 Offline OP
Halifax, VA.
Originally Posted by Sniper
Is this on a flathead or did you swap something more modern in? I ask because I have a 51 Plymouth I want to add AC too, but keep the flat head.
I expect it can be done easily. Only "concern" would be brackets, and they can be made without much trouble or cost.
Jack
K.I.S.S.
Re: AC ?? [Re: BcudaChris] #2703433
10/03/19 02:47 PM
10/03/19 02:47 PM
Halifax, VA.
Halifax, VA.
Originally Posted by BcudaChris
If it freezes up with cleared drains, I'd open your hot water valve and the return a bit and see if that prevents the evap from icing up. You'll probably have to mess with it to get enough heat into the air to prevent freeze, but not enough to warm up your chilled air.
Hell, that sounds like a plan. I'll give it a shot.
Thanks,
Jack
K.I.S.S.
Re: AC ?? [Re: moparjack44] #2708869
10/21/19 01:28 PM
10/21/19 01:28 PM
Halifax, VA.
Halifax, VA.
Originally Posted by moparjack44
Thanks everyone. I checked Vintage Air website, they have a very good online Tech, that was helpful also. I will check to sure upon original install, I did the correct order. Will be going on another long trip on Oct 11th to car show and drags at Dunn NC. I will let you know how/if the AC works OK..
Thanks,
Jack
Did not get to make the trip to Dunn. I did check and found AC was low in freon. I filled it up, but the weather has made a dramatic drop in temperature here and have not needed to use the AC. Maybe next year up. Thanks for everyones input.
Jack
K.I.S.S.
