16" DOT stickys. What are my options?
#2702453
09/30/19 11:16 PM
09/30/19 11:16 PM
Posts: 7,494 Minnesota
Hemi_Joel
Minnesota
I might have an opportunity to snag a pair of vintage n.o.s. magesium rear wheels for my coupe. But they are 16x10. This is for Drag Week, and I do not swap tires. So if I bought them I would need some 16 in. DOT Sticky's. It's a stick car so I should probably go with bias plies. are there any good options in 16 inch, or should I forget about these wheels and hold out for some 15 by tens?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: 16" DOT stickys. What are my options?
[Re: Hemi_Joel]
#2702481
10/01/19 06:00 AM
10/01/19 06:00 AM
Posts: 12,396 Taxes & Virus's R-US, NY
Dragula
Hoosier Quick Time Pro's seem to be about the best out there....Lots of guys in the street outlaw class run them....I run them...1.33 60ft on them this year with leaf springs.
[Re: hemi-itis]
#2703035
10/02/19 01:17 PM
10/02/19 01:17 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
M&H makes a 30/14/16 cheater slick bias which would probably work well, they actually call for a 10" wheel. Its supposedly 14 section, 11 tread. http://www.mandhtires.com/M-H-Racemaster-Cheater-Slicks/30-14.0-16LT
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: topfueldart]
#2703095
10/02/19 03:48 PM
10/02/19 03:48 PM
Hemi_Joel
Minnesota
Thanks for the info! Looking at availability, it would probably we wise for me to pass on the 16" wheels and hold out for some 15's. Many more tire choices. 10-12" wide, vintage magnesium, 4-3/4 bolt pattern is what I need.
