Re: 413 engine ID help wanted [Re: ossietim] #2702663
10/01/19 04:05 PM
10/01/19 04:05 PM
Chattanooga, TN
orange elephants Offline OP
Chattanooga, TN
So the 1959 Chrysler 300E engine ID starts with MR413. So is this engine from a 300E, or did Chrysler use that designation on other engines? The engine has a single 4 barrel intake and Imperial valve covers. I found a reference on the Imperial Club website saying their Imperial engine was stamped MR413, and nobody seemed to know what that meant on an Imperial engine, since Imperial engines are supposed to start with Y.
Re: 413 engine ID help wanted [Re: NANKET] #2702675
10/01/19 04:37 PM
10/01/19 04:37 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Originally Posted by NANKET
I wasn’t asking if you thought I was right. I wasn’t guessing. I was telling you what these numbers mean. But hey, you never believed me on other items before, so here is your proof today. Notice how the build date doesn’t appear on the stamped pad until 1960 model year.
Pardon me all to hell for encroaching on your area of expertise but I wonder if you noticed the contradictory info in your posts.In a previous post you declare "[9004 is not a build date it is a serial number," but in the chart you posted it shows a date on the top pad. I highlighted the '61 info you posted. If the 9004 is, indeed, a serial number, it doesn't fit any serial number format that I'm familiar with. Explain? Or is it a sequence number rather than a serial number?
Re: 413 engine ID help wanted [Re: John_Kunkel] #2702701
10/01/19 05:34 PM
10/01/19 05:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You missed it maybe?
He said
Quote
Re: 413 engine ID help wanted [Re: Alaskan_TA] #2702717
10/01/19 06:48 PM
10/01/19 06:48 PM
Rio Linda, CA
Rio Linda, CA
The subject engine is a '61 so, accordingly, the date is on the pad.
Re: 413 engine ID help wanted [Re: John_Kunkel] #2702720
10/01/19 07:01 PM
10/01/19 07:01 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
But he said
Quote
A 1961 will have R41 with the 3 missing.
& the OPs engine has the full 413. work
Re: 413 engine ID help wanted [Re: Alaskan_TA] #2702779
10/01/19 09:53 PM
10/01/19 09:53 PM
Chattanooga, TN
Chattanooga, TN
I think the confusion here may be that the reference materials say the block casting number is for a 1961 413, but the ID stampings do not match anything from 1961. It could be that the block was cast in 1961, and the stamps on the ID pad are just wrong. It could also be that the reference materials are incomplete, and the casting number could have been used in 1959 and 1960 as well as 1961.
If the casting number is correct, the engine is a 1961. If the stamping is correct, it is from a 1959 300E. It wouldn’t be the first time reference materials for casting numbers was wrong or incomplete, so I’ m leaning toward this being a 1959 300E engine.
Re: 413 engine ID help wanted [Re: orange elephants] #2702783
10/01/19 10:20 PM
10/01/19 10:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
A photo of the casting date would help.
Re: 413 engine ID help wanted [Re: orange elephants] #2703221
10/02/19 09:22 PM
10/02/19 09:22 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Casting number for 1959 is likely the same. Might be the same for every 413, but I'm not certain. That is the problem with reference books that start and end in a certain year.
