B engine windage tray #2701696
09/28/19 11:47 AM
09/28/19 11:47 AM
WASHINGTON
superbee471 Offline OP
WASHINGTON
I am assembling a B engine 500 cbi for race and noticed that the windage tray was almost an inch or slightly more away from the crankshaft at its closest point. I then set a non stroker windage tray on and looked again, it was about 3/8 inch away from the crank at its closest point. My question is , are the any advantages or disadvantages to being closer or farther away from the crank with a windage tray? Any knowledge or thoughts on this ?
Re: B engine windage tray [Re: superbee471] #2701754
09/28/19 03:06 PM
09/28/19 03:06 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You want the tray to keep the sump oil away from the crank. Some of those "stroker" trays are way too deep and won't even fit inside some oil pans.
If the tray is deeper in the oil pan than the oil level, it is not doing anything.
So the closer to the crank is generally better as long as the trays baffles can get rid of excess oil around the crank.
Re: B engine windage tray [Re: 451Mopar] #2703334
10/03/19 09:02 AM
10/03/19 09:02 AM
WASHINGTON
WASHINGTON
Thank you for the wisdom. after looking at it again 1 inch away from the crank is way too far. Will go with the standard windage tray .
Re: B engine windage tray [Re: 451Mopar] #2703380
10/03/19 11:51 AM
10/03/19 11:51 AM
iagree
Have you thought about buying or building a crankshaft scraper, they really help up scope
Re: B engine windage tray [Re: Cab_Burge] #2703682
10/04/19 04:22 AM
10/04/19 04:22 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
My 4.25" stroke crank with 7.25" counter weights cleared a stock mildon replacement windage tray.
