Re: Head Porting Questions... [Re: fast68plymouth] #2708719
10/20/19 11:44 PM
10/20/19 11:44 PM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
Originally Posted by fast68plymouth
I’d bullet nose the guides.
Don’t go nuts though.
It’s easy and there’s no water there.
This is what I started with on the 346 head above:
I didn't get a ton of time to work on them today but I did get 12 of the bosses bullet nosed and also cleaned up the exhaust ports a bit. Although I wasn't sure initially about working the guide bosses, I'm glad I did it. You can really see a difference in the port opening after the fact. Hopefully I'll get some free time after work this week to finish them up. Anyhow, thanks for the push. I appreciate it. beer -Trent
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Head Porting Questions... Updated with Flow Numbers [Re: fast68plymouth] #2720261
11/29/19 02:58 PM
11/29/19 02:58 PM
Tucson AZ,
Tucson AZ,
Finally got them on the flow bench... In hindsight, there are a few things I wish I had done differently but since this is a budget build and my time to work on projects is few and far between, I'll take them for what they are, at least for now.
Just to recap, these are 452 heads with 2.08 / 1.74 valves, template porting, gasket matched, pushrod pinch opened up a bit and bullet nosed guide boss. They are going on a 413 which is why I retained the stock valves to prevent cylinder wall shrouding. It's also worth noting that these cores came off my work truck with a ton of miles on them. We did install new guides but reused the existing valves. As a result, the intake valves are fairly deep in the heads which is kind of a bummer. I'm sure that if I had replaced the valves and spent a bit more time on the port work, I could have gotten better results. However, I chose my stopping point and this is what I got.
Honestly, I really don't mind porting but if you consider the cost of valves, guides, hardened seats, labor, etc, it makes it really hard to stick with iron heads. That being said, I'm thinking a pair of Sidewinder or Stealth heads will be a better starting point for my future "budget builds"...
Re: Head Porting Questions... Updated with Flow Numbers [Re: MadMopars] #2720278
11/29/19 04:15 PM
11/29/19 04:15 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Nice job....... should run pretty good!
Notes on flow sheet....... ex with tube.
Any idea what sized tube?
Re: Head Porting Questions... Updated with Flow Numbers [Re: MadMopars] #2720284
11/29/19 04:45 PM
11/29/19 04:45 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Thats good #'s, As Dwayne said it should run good.
Re: Head Porting Questions... Updated with Flow Numbers [Re: fast68plymouth] #2720915
12/02/19 03:38 PM
12/02/19 03:38 PM
Tucson AZ,
Tucson AZ,
Sorry for the late response, I was waiting for confirmation. Testing was done with a 2" primary. I assume that's typical? shruggy
Re: Head Porting Questions... [Re: MadMopars] #2720927
12/02/19 04:13 PM
12/02/19 04:13 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice work!..any pics?
