engine sat dormant for 40 years #2700897
09/25/19 06:53 PM
09/25/19 06:53 PM
Ontario Canada
Bennoel 10 Offline OP
Ontario Canada
acquired a 71 340 engine that has sat in a old barn floor for 40 years. dragged it home and now before I try to turn it over I'm wondering what steps to take. I can see one
exhaust valve is open and some rust. Any suggestions as to what I should put in the cylinders ie.. engine oil, diesel fuel etc... Going to remove spark plugs and try to look
inside with a scope. Take the valve covers off and back off the rocker shafts??? Anyway just looking for any suggestions and thanks to all.
Bennoel
Re: engine sat dormant for 40 years [Re: Bennoel 10] #2700898
09/25/19 06:57 PM
09/25/19 06:57 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Why not just pull the heads off?
Re: engine sat dormant for 40 years [Re: Bennoel 10] #2700901
09/25/19 07:05 PM
09/25/19 07:05 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
Just put a breaker bar on the crank bolt and see if it turns. no big deal, if it does it does. If it does not then you will go to step 2 ....find out why. what are your plans for this engine? Do you have any? don't over think it. If it turns good. if it doesn't. well see step 2. Was the barn dry? do you have history on the engine? you wont hurt anything by just trying to turn it the way it is. Report back
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: engine sat dormant for 40 years [Re: yella71] #2700902
09/25/19 07:12 PM
09/25/19 07:12 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Sitting in that kind of environment ,. At the very minimum I would pull the heads and oil pan to take a look.
I opened up a 440 that had been sitting in the car for about 15 years and found all kinds of surface rust in the bores. It was inside a dry garage with concrete floors . Never tried to turn it over, owner said pull it and go thru it.
Re: engine sat dormant for 40 years [Re: forphorty] #2700905
09/25/19 07:16 PM
09/25/19 07:16 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree It's not like it's going to be a runner beer
Re: engine sat dormant for 40 years [Re: Bennoel 10] #2700991
09/26/19 12:12 AM
09/26/19 12:12 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Bennoel
More likely have mechanical welding of rings to walls.
Pull heads, rap the top of pistons with a large rubber/wooden mallet.
Spray everything with liquidwrench (or equiv), let set awhile
Then attempt to turn via damper
Re: engine sat dormant for 40 years [Re: PhillyRag] #2701045
09/26/19 09:29 AM
09/26/19 09:29 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
A friend of mine got a free 283 Chevrolet for a T-bucket project he was working on. It had been outside for years and was locked up solid. We filled the cylinders with diesel fuel and let it sit for an hour or so. Then we rocked around on the breaker bar and pry bar on the flex plate and it broke loose. Put some fresh oil in it and fired it on the test stand. It smoked like crazy for a few minutes then quit and ran nicely. He changed the cam and heads and beat that thing like a rented mule in that t-bucket for several thousand miles before he sold it.
Not saying this is a good idea but I would try and make it run, but I think that kind of challenge is fun.
68 Barracuda Formula S 340
Re: engine sat dormant for 40 years [Re: Bad340fish] #2701047
09/26/19 09:36 AM
09/26/19 09:36 AM
God's Country Maryland
GODSCOUNTRY340 Offline
40 years? That 340 is most likely not going to turn over. Even if it did there will be valves stuck open and the pistons will hit them. Plan on a full rebuild. Pull the heads, soak the pistons with Kroil, let set for a couple days, soak again and maybe they'll come loose.
Re: engine sat dormant for 40 years [Re: Bad340fish] #2701086
09/26/19 11:31 AM
09/26/19 11:31 AM
moparx Offline
moparx  Offline
did the same to a 392 in a 58 imperial, only we used ATF.
boy did that baby smoke ! eek
beer
Re: engine sat dormant for 40 years [Re: Bad340fish] #2701134
09/26/19 01:40 PM
09/26/19 01:40 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
... and beat that thing like a rented mule ...
laugh2 laugh2 laugh2 laugh2
I haven't heard that in a very long time. My Dad used to say it. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: engine sat dormant for 40 years [Re: I_bleed_MOPAR] #2701173
09/26/19 03:48 PM
09/26/19 03:48 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I saw an episode of Chasing Classic cars and the old guy "Roger" used Marvels Mystery oil on an engine / vehicle that had been sitting for many years. They removed the spark plugs and used MMO in the cylinders. After allowing it to soak for a few days, they placed the vehicle in gear and gently rocked the car, finally freeing up the engine. I enjoy when they show crusty old Roger and his tricks of the trade. The guy has been around a long time and appears to have knowledge about all kinds of vehicles. Perhaps investigate using MMO if you don't take off the heads etc. per other suggestions.
Re: engine sat dormant for 40 years [Re: cruzin] #2702126
09/29/19 10:42 PM
09/29/19 10:42 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Always thought Marvels Mystery Oil was just ATF. Did they use to put a quarter in the can as a sale incentive (gas station)? I think a total rebuild is in order.
Re: engine sat dormant for 40 years [Re: SALEM1912] #2702141
09/30/19 12:39 AM
09/30/19 12:39 AM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
If they did, it would be a silver quarter. It would be worth about $3.15 on todays junk silver market.
Re: engine sat dormant for 40 years [Re: John Brown] #2702150
09/30/19 01:37 AM
09/30/19 01:37 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
34 years sitting...I used wd40 in the cylinders, sprayed it in with the straw and tried to spread it all around in the cylinders.I sprayed once or twice a week for months..just letting it sit and soak...then spun it with a flywheel Turner and it broke free..sprayed more wd40 and rotated the engine some more..then new plugs, fresh gas from a can into the fuel pump then...
https://youtu.be/OSkDnAzu9w8
Re: engine sat dormant for 40 years [Re: AARCONV] #2704739
10/07/19 11:11 PM
10/07/19 11:11 PM
WA 98043
thecarfarmer Offline
WA 98043
When I was 17 or 18, I got a 239 Ford that had been sitting out in a guy's backyard with a tin can over the carburetor for heaven knows how many years.
Fresh plugs, fresh points, kit in the carb. Ran like a Swiss watch.
I suspect this was only because of my ignorance - had I known better, it probably wouldn't have ran at all...
Fast forward 3 decades. Bought a 2002 Sportster engine with 3000 miles on it; pulled from a wrecked bike. went to put cams in it, check the crank run out while the cam chest was open and found almost .006" TIR on the pinion shaft. Tearing the motor apart so I could split the cases and true the crank, found one of the cylinders had got condensation in it.
Basically, if I had tried to run that motor as it was, I wouldn't have got much life out of it.
Like previous postershave pointed out, a gasket set is not terribly expensive. If the motor gets torn down, and everything is just fine, then it goes together with nothing more than the gasket kit.
If there's issues, probably not going to get any cheaper to fix by running it
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: engine sat dormant for 40 years [Re: thecarfarmer] #2705726
10/10/19 10:26 PM
10/10/19 10:26 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Even if it turns, what is the point of not taking it apart. You said you already see rust in the bore. This will not have a good hone, valve job, valve stems or ring tension.
Take it apart and rebuild it properly.
Re: engine sat dormant for 40 years [Re: Magnum] #2706388
10/13/19 12:38 PM
10/13/19 12:38 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Any time I work on an eng.that has sat for awhile I put a couple of OZs of ATF in each cyl. & then use compressed air with a hose/pipe going into the cyl. to blow the ATF around the cyl. so I know the entire cyl.has gotten lubed,let it set for awhile & then see what happens,Ill also lube the valve train well & if possible spin up the oil pump to lube the bearings,or if the eng.frees up Ill crank it around w/o plugs to pump up the oiling syst.
