dist timing falls off #2700998
09/26/19 12:49 AM
09/26/19 12:49 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
got one of the mopar /mallory adjustable distributors with a collar to limit play .
set timing at 34 at 3000 and it drops to 26 by 4000 rpm ????
vac disconnected
crome box big accel coil 1.25 resisstor
ideas entertained !
thank you !
Re: dist timing falls off [Re: calrobb2000] #2701001
09/26/19 02:05 AM
09/26/19 02:05 AM
AndyF Offline
AndyF  Offline
The chrome box is probably bad. Try a different box.
Re: dist timing falls off [Re: calrobb2000] #2701003
09/26/19 02:50 AM
09/26/19 02:50 AM
Cab_Burge Online work
Cab_Burge  Online Work
I've seen that when a low deck BB distributor was used in a SB LA motor, all BB distributors are intended to rotate counter clockwise and all LA SB and early Mopar V8 with the distributors in the rear rotate clockwise work scope
I've also seen what Andy is saying on after market ECU shruggy
Re: dist timing falls off [Re: calrobb2000] #2701013
09/26/19 05:50 AM
09/26/19 05:50 AM
Aus
hysteric Offline
hysteric  Offline
Aus
Originally Posted by calrobb2000
hi
vac disconnected
ideas entertained !
thank you !
I have a YH mallory and it does the same thing. It hits 38 degrees at 3000 RPM then drops to 35. My understanding is as the weights hit the limiter they retard as the vibrational forces cause them to bounce.
If you look at the original Mopar Performance Distributors they place a very strong spring with a long loop with a very light spring so as the advance rises rapidly and then the slack is taken up and then the heavy spring begins to limit the advance to a slower rate. There is slew rate but i don't think that is the issue here.
What springs are you using? You could try a light spring and a heavy spring
