Re: engine sat dormant for 40 years
[Re: Bennoel 10]
#2700901
09/25/19 07:05 PM
09/25/19 07:05 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
Just put a breaker bar on the crank bolt and see if it turns. no big deal, if it does it does. If it does not then you will go to step 2 ....find out why. what are your plans for this engine? Do you have any? don't over think it. If it turns good. if it doesn't. well see step 2. Was the barn dry? do you have history on the engine? you wont hurt anything by just trying to turn it the way it is. Report back
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: Bennoel 10]
#2700991
09/26/19 12:12 AM
09/26/19 12:12 AM
Posts: 1,757 Phila
PhillyRag
Phila
acquired a 71 340 engine that has sat in a old barn floor for 40 years. dragged it home and now before I try to turn it over I'm wondering what steps to take. I can see one exhaust valve is open and some rust. Any suggestions as to what I should put in the cylinders ie.. engine oil, diesel fuel etc... Going to remove spark plugs and try to look inside with a scope. Take the valve covers off and back off the rocker shafts??? Anyway just looking for any suggestions and thanks to all. Bennoel More likely have mechanical welding of rings to walls. Pull heads, rap the top of pistons with a large rubber/wooden mallet. Spray everything with liquidwrench (or equiv), let set awhile Then attempt to turn via damper
[Re: PhillyRag]
#2701045
09/26/19 09:29 AM
09/26/19 09:29 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
A friend of mine got a free 283 Chevrolet for a T-bucket project he was working on. It had been outside for years and was locked up solid. We filled the cylinders with diesel fuel and let it sit for an hour or so. Then we rocked around on the breaker bar and pry bar on the flex plate and it broke loose. Put some fresh oil in it and fired it on the test stand. It smoked like crazy for a few minutes then quit and ran nicely. He changed the cam and heads and beat that thing like a rented mule in that t-bucket for several thousand miles before he sold it.
Not saying this is a good idea but I would try and make it run, but I think that kind of challenge is fun.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2701047
09/26/19 09:36 AM
09/26/19 09:36 AM
Posts: 2,533 God's Country Maryland
GODSCOUNTRY340
40 years? That 340 is most likely not going to turn over. Even if it did there will be valves stuck open and the pistons will hit them. Plan on a full rebuild. Pull the heads, soak the pistons with Kroil, let set for a couple days, soak again and maybe they'll come loose.
[Re: SALEM1912]
#2702141
09/30/19 12:39 AM
09/30/19 12:39 AM
Posts: 1,848 South Bend
John Brown
South Bend
If they did, it would be a silver quarter. It would be worth about $3.15 on todays junk silver market.
[Re: AARCONV]
#2704739
10/07/19 11:11 PM
10/07/19 11:11 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
When I was 17 or 18, I got a 239 Ford that had been sitting out in a guy's backyard with a tin can over the carburetor for heaven knows how many years.
Fresh plugs, fresh points, kit in the carb. Ran like a Swiss watch.
I suspect this was only because of my ignorance - had I known better, it probably wouldn't have ran at all...
Fast forward 3 decades. Bought a 2002 Sportster engine with 3000 miles on it; pulled from a wrecked bike. went to put cams in it, check the crank run out while the cam chest was open and found almost .006" TIR on the pinion shaft. Tearing the motor apart so I could split the cases and true the crank, found one of the cylinders had got condensation in it.
Basically, if I had tried to run that motor as it was, I wouldn't have got much life out of it.
Like previous postershave pointed out, a gasket set is not terribly expensive. If the motor gets torn down, and everything is just fine, then it goes together with nothing more than the gasket kit.
If there's issues, probably not going to get any cheaper to fix by running it
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: thecarfarmer]
#2705726
10/10/19 10:26 PM
10/10/19 10:26 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Even if it turns, what is the point of not taking it apart. You said you already see rust in the bore. This will not have a good hone, valve job, valve stems or ring tension.
Take it apart and rebuild it properly.
